Poor mans transmission cooler
Old Mar 24, 2012 | 06:53 PM
inputapmech's Avatar
inputapmech
Default Poor mans transmission cooler
I have a 2006 C6 with A6 trans and this thing has never run what I consider in an acceptable temperature range (less than 180 deg).
While under the car I noticed that GM in their infinite wisdom ran the
transmission cooler lines 3/4 to 1/2 an inch from the right catalytic
converter pipe. This pipe gets 700-900 degrees so I thought I would
get some header wrap and insulate that portion of the pipe. My trans
temps in stop and go traffic were over 200 degrees now I have lost
10-20 degrees of temp by wrapping the exhaust pipe. Total cost $20
for 10' header wrap and 2 hose clamps. 15 minutes invested and worth
the money I think........
Old Mar 25, 2012 | 05:49 AM
locosmith's Avatar
locosmith
Smart. How do you find your tranny temp?
Old Mar 25, 2012 | 09:04 AM
inputapmech
Default Trans Cooler
Your Driver Information Center (gauge cluster) will give you the trans temp with the press of the button.
Old Mar 25, 2012 | 09:58 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
The lines are even closer than that when you add headers. I wrapped the lines themselves but never checked if it made a difference in temps.
Old Mar 25, 2012 | 03:46 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Another reason to have the headers ceramic coated.
San
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Anyone else do this and get some comparison numbers?
My A6 temps vary so much from day to day, and different driving conditions, that I'd need to do some very precise testing to see how much the temp had changed.
Old Jun 21, 2012 | 03:21 PM
locosmith's Avatar
locosmith
can you see tran temps if you have an 05 z51? Cuz all I see is oil temp but not specifically tranny oil, same thing?
Old Jun 21, 2012 | 08:55 PM
calemasters's Avatar
calemasters
It has nothing to do with RPO Z51. If you have a manual transmission, no transmission oil temperatures are displayed. If you have an automatic, the transmission oil temperature can be displayed.
The oil temperature you see displayed is the engine oil temperature, so that is not the same as the transmission oil temperature.
Old Jun 23, 2012 | 03:39 AM
locosmith's Avatar
locosmith
Ah thx, yeah it's a manuel. Good to know
Old Jun 23, 2012 | 08:35 AM
Atomic C6's Avatar
Atomic C6
Default good tip
the trans temps are to high on the factory set up. I am going to give this a try thanks!
Old Jun 24, 2012 | 10:59 AM
OMG's Avatar
OMG
I'm surprised nobody's tried to reroute it yet. Does the manual have a trans cooler line? Or is it just for auto's?
Old Jun 25, 2012 | 12:16 PM
Atomic C6's Avatar
Atomic C6
Default Trans cooler
I took this one step further and put a heat sleeve over the trans lines and sprayed the header wrap with high temp silicone spray paint. The spray paint not only helps with heat but protects the thermal wrap.
Old Jun 26, 2012 | 02:52 AM
HC Mechanic's Avatar
HC Mechanic
San
Old Jun 26, 2012 | 06:46 PM
Atomic C6's Avatar
Atomic C6
Default pics
here are two pics of the finished product.
To Poor mans transmission cooler
