Old Mar 3, 2015, 12:30 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Multiple Cylinder Misfire Code P0300 Help!
Old Feb 13, 2022 | 10:17 AM
Jeredk21's Avatar
Jeredk21
Originally Posted by omspray
Did this resolve your issue ??
Ended up being worm out couplers in the torque tube. This caused a little play and and false readings from the sensor
Old Feb 13, 2022 | 11:57 AM
omspray's Avatar
omspray
7th Gear
Default torque tube
Glad you got it !!! same way with mine !!
Old Apr 15, 2022 | 05:02 PM
yourboy_blu's Avatar
yourboy_blu
Default P0300 but different
So driving on the Turnpike did a pull to 110, no issues. 5 minutes later cruising at 85 and i get the flashing CEL with what feels like a misfire. As i try to limp it off the Pike, i notice the car won’t run unless it’s moving in gear (tried to coast in neutral but had to pop the clutch to keep it going). Got it to a gas station and **** it down, temps only slight above normal. Scanner and onboard show P0300. Steam was coming from the dipstick when checked and the oil filler cap looks like it could have coolant mixed. Fml. Aside from an oil change, any idea what to look for when I tear into this? (Waiting on a tow truck currently)
Old Apr 17, 2022 | 07:44 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Well if you have a bad head gasket or worst case a cracked head and got coolant or loss of compression in the cylinder there is your misfire !!…an oil change unfortunately won’t fix this “chocolate milkshake”…you can get a test kit from Bar’s or maybe do a compression test to diagnose this !!
