harmonic balancer/damper
Old Apr 2, 2012 | 10:44 AM
montereyredvette's Avatar
montereyredvette
Default harmonic balancer/damper
Has GM updated this part ,or is a new one the same POS thats wobbling in my car now.
Old Apr 2, 2012 | 11:20 AM
ricknyc23's Avatar
ricknyc23
PM me if you want details of what Im going through
Old Apr 2, 2012 | 12:38 PM
wysiwyg's Avatar
wysiwyg
Same part.
I had my harmonic balancer replaced under warranty last month.
The new balancer has a very slight wobble which is barely noticeable.
It is definitely better than the old balancer it replaced.
It appears this is a common issue with the OEM balancer.
Old Apr 2, 2012 | 07:48 PM
C6topless's Avatar
C6topless
Just put mine into the dealership for repair .... I will let you how it goes.
Old Apr 3, 2012 | 11:44 AM
Gering's Avatar
Gering
Tolero Apto Victum
OP: If you are having problems with your stock oem unit, please take a look at an ATI unit.
Old Apr 3, 2012 | 12:49 PM
montereyredvette
My car is out off warranty. GM Canada has aggreed to pay 25% of the $1300 repair. I'll get it done and sue in small claims court for a refund AND damages.
GM Customer service SUCKS!
C6 Topless...are you still under warranty??
Old Apr 3, 2012 | 07:34 PM
C6topless's Avatar
C6topless
Lucky for me, my warranty is not yet expired. If it was expired, I would not be at the stealership and I would be putting in an aftermarket one..Personally, although I know how to do the install and have the tools, I just hate doing it as it is a pain in the @ss.
Old Apr 3, 2012 | 07:37 PM
C6topless's Avatar
C6topless
Also the ATI unit will be going into my vette the next time it goes out. They are highly reliable and have an excellent history with the LS2 engine.
Old Apr 3, 2012 | 11:30 PM
montereyredvette
C6topless
A couple of forum members claim their Dealers are waiting for updated harmonic balancers...you should ask your Service guy about this.
Old Apr 3, 2012 | 11:37 PM
Gering's Avatar
Gering
Tolero Apto Victum
Old Apr 4, 2012 | 09:27 AM
ricknyc23's Avatar
ricknyc23
As an FYI, if your dealer has one in stock, he probably wont know about the new ones set to come out. My dealer only found out about it when he had to open a **** case. GM is working with a new vendor to manufacture a new improved part.
C6topless
Old Apr 4, 2012 | 07:54 PM
C6topless's Avatar
C6topless
I am on the "waiting list" for a harmonic balancer... Seems there is a severe back order right now. I was quoted the 12th of April as the earliest my dealer can get one in stock. Seems there is a new vendor involved.
btw---- I tried to work a deal with the dealer to install a ATI which I would provide them and they would provide the labor. They are considering it if they cannot get a harmonic balancer in a reasonable amount of time. Others on the wait list may try this approach if you are close to the warranty ending.
Old Apr 4, 2012 | 08:16 PM
ricknyc23's Avatar
ricknyc23
I guess if yours is due on the 12th, I should get mine soon because I've been waiting two weeks....
They won't do the ATI, I asked them....
Old Apr 4, 2012 | 08:51 PM
Gering's Avatar
Gering
Tolero Apto Victum
That sounds like a win win for both parties... IMO
Old Apr 4, 2012 | 10:51 PM
cryoman07's Avatar
cryoman07
Been waiting for two.weeks now. Joined the forum to see if this a.common problem..... Apparently it is.
Old Apr 5, 2012 | 12:04 AM
C6topless's Avatar
C6topless
Cryoman ...it is a problem that has existed since the introduction of the C6 and the quick fix they tried did not work. It is a definite design flaw as the failure rate is way too high. It does not suprise me that a new design / vendor is being sought now.
Old Apr 5, 2012 | 12:27 AM
cryoman07's Avatar
cryoman07
Once they fix it under warranty, and it goes out again aftermarket is going on.
To harmonic balancer/damper
Old Apr 5, 2012 | 03:11 AM
debo's Avatar
debo
The dealer replaced mine the first time with factory unit, but still not fixed. I'm still under extend warranty and going to try and have them install aftermarket piece.
Old Apr 5, 2012 | 11:27 AM
cryoman07's Avatar
cryoman07
I might try and get them to replace it with aftermarket. Anyone have experience with ATI or Trick flow???
Old Apr 5, 2012 | 11:38 AM
ricknyc23's Avatar
ricknyc23
I've asked them to replace it with an ATI. They wont do it...
