C6 Electrical Connectors
Old Apr 8, 2012 | 07:57 PM
webhale's Avatar
webhale
Cruising
Default C6 Electrical Connectors
I have a need to know the electrical connector (male and female) part numbers for the following switches on a C6:
Fuel /Trunk
Hazard
Door Lock
Seat Memory
Where can i find this info?
Old Apr 8, 2012 | 09:42 PM
Zoxxo's Avatar
Zoxxo
Fuel /Trunk
Hazard
Door Lock
Seat Memory
The info is in the original service manuals (at least.( Of course in a lot of cases these connectors aren't free-standing and are built into the switch. So, while you might know the manufacturer's part # for the connector (and you can usually use the internet to work backwards from there to get both the male and female part numbers,) it may or may not be meaningful for use on the car.
I've had fairly good luck at finding GM connectors via the Mouser Electronics online catalog.
That said...
1. The rear compartment lid release (interior) connector:
OEM: 12089248
Service: 12102900
4-way F Metri-Pack 150 Series (NA) (F=female)
2. The fuel door release switch connector is the same as above.
3. Hazard
OEM: 174966-2
Service: 88953314
4-Way F .040 Series Multilock (black)
4. Door lock - interior
OEM: Assembly = 15354716
OEM: Connector = 15354717
PLR: 15326558
Seal: 12040756
4-way F GT Series Sealed (black)
5. Door lock - exterior
OEM: 15332135
Service: 15306414
4-way F GT 150 Series (black)
6. Memory Seat Switch
OEM:12092062
Service: 15306021
4-way F Metri-Pack 150 series (black)
Hope that helps.
Z//
Old Apr 8, 2012 | 10:02 PM
webhale's Avatar
webhale
Cruising
I can't believe you provided this info so quickly. Thanks for you help.
Old Apr 9, 2012 | 07:42 PM
webhale's Avatar
webhale
Cruising
If you can provide one more connector part number for the 12V Accessory, it would help.
Old Apr 9, 2012 | 10:54 PM
Zoxxo's Avatar
Zoxxo
The AUX power outlet (under the lid of the center console):
OEM: 12176446
Service: 15305985
3-way F Metri-Pack 280 Series, Flexlock (black)
Cigarette lighter:
OEM: 12176445
Service: 15305919
Z//
Old Apr 10, 2012 | 09:55 AM
webhale's Avatar
webhale
Cruising
Thanks for your help.
Old Apr 15, 2021 | 10:19 PM
NVRTRKD's Avatar
NVRTRKD
I broke a couple connectors during a recent clutch replacement, how did you find these part numbers?
Old Apr 16, 2021 | 11:43 AM
Dano523's Avatar
Dano523
GMSI, and the connectors are a lot cheaper if you buy them and connector pins from Mouser.
Old Apr 16, 2021 | 03:19 PM
NVRTRKD's Avatar
NVRTRKD
$1200/year seems expensive is there another way to get it?
Old Apr 16, 2021 | 10:01 PM
4SUMERZ's Avatar
4SUMERZ
Pm me your e-mail and I'll send you the PDF for all 305 connector info for a 2008. I'm certain that the connector part numbers are standard across the C6 model. The pinout info may be different for various years however. But since you have a 2008, everything will be correct.
To C6 Electrical Connectors
