Wideband?
I also am looking for a decent boost guage, wireless if anyone has recommendations for that.
I used too have a turbo Escort and the wideband I used on that car had an analog output for the PCM, has anyone tried using that output with this car? Anything I can do too eliminate the service engine light for no heater circuit code, or just have the tuner disable the codes?
https://www.palmerperformance.com/st...products_id=76
I also believe that this AEM can do the same thing, but not sure you will have to read a little more - I do know that it uses piggybacks the OBD2 port, but not sure if it will read on the HUD like the Dashlogic
https://www.aemelectronics.com/produ...and-uego-obdii
Thanks,Matt
