Cam Question
Old Apr 10, 2012 | 10:34 PM
Vette'n04's Avatar
Vette'n04
Default Cam Question
I'm not sure if this question has been asked this way before so I'll try it. I'm contemplating putting a cam in my car with the LS3. Now here is the "issue.". I want a cam that will give me an extra 50-75 HP BUT I don't want to sacrIfice drivability or durability. I don't track the car and this would just be for the street. In fact I would prefer the car to drive as close to stock as possible, say 95%. Internally the motor is presently stock. The only external modifications are a vararam, Z06 exhaust manifolds, x pipe and a tune.
Is there such a cam out there that will allow me to meet my parameters?
I might add that at some future date I would consider a supercharger.
Thanks for the help.
Old Apr 10, 2012 | 11:59 PM
taken19's Avatar
taken19
Track Junky
I'm no cam expert, but I can't see you adding a cam that will produce 50-75 rwhp and still drive near stock. That type of cam will most likely have a nasty lope and marginal street manners, especially if you are aiming for the top end of your band. A "mild" cam than drives near stock will typically net you 35-45 rwhp, depending on specs.
Old Apr 11, 2012 | 12:08 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
taken19 is right. Besides, if you're thinking supercharger in the future, you probably don't want a large cam.
San
Old Apr 11, 2012 | 12:22 AM
sam90lx's Avatar
sam90lx
Check Mast Performance, I think they have the cam for you! Like stock and 50hp I think.
Also Geoff with EPS.
With the Mast cam you will give up some bottom end and the extra 50 comes on around 5-6k
Old Apr 11, 2012 | 02:50 PM
lowriderflow's Avatar
lowriderflow
Check out the Lingenfelter GT11 cam
Old Apr 11, 2012 | 03:01 PM
08VRZ06's Avatar
08VRZ06
Cruise-In X Veteran
Katech 110. Sounds Great at Idle and good street manners. If you don't want that much cam try a Katech 116, same lift and duration as the 110 but with no overlap.
Mark
Old Apr 11, 2012 | 04:27 PM
mattdracing's Avatar
mattdracing
what he said ^^ i have heard nothing but great things about the katech 110 and 116 cam. 110 just sounds a little more aggressive but still drives well. that will be my cam choice when i find the $$
Old Apr 11, 2012 | 04:55 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Mark
Am I missing something or are both of those for the LS7?
http://store.katechengines.com/camsh...-parts-c4.aspx
San
Old Apr 11, 2012 | 05:03 PM
sallen619's Avatar
sallen619
I decided the way to achieve the goal and keep the driveability was to get a smaller cam and get the heads ported...
I'm very pleased with my results.
Old Apr 11, 2012 | 06:18 PM
Vette'n04's Avatar
Vette'n04
Lots of opinions here, and I thank all of you who offered theirs. I will research them all.
I should have been a little more specific in what I wanted from a cam.
Like I said, almost a stock feel, but I want most of the power in the lower to mid RPM range where most of my driving is done, say 3000-4500.
Old Apr 11, 2012 | 06:33 PM
mattdracing
San
you may be right...i thought they made a cam for the ls3 but they may only do the ls7
Old Apr 11, 2012 | 06:51 PM
ctusser's Avatar
ctusser
That won't give 50hp.
To Cam Question
