Tech2 vs MDI?
I have a 2012, and want to be able to do a few things (read codes, control the bi-directional stuff, etc). None of the standard tuning or scan tools seem to be able to do much beyond the Engine or Transmission modules (I have a scan tool and a EFILive). I really do miss the ability to review codes like we could on the C5!
It "appears" that the Corvette still uses the Tech 2 for 2012 ???
The Helm manual will not be out until August so it is no help.
Certain GM cars are starting to require the MDI tool, but from what I have read, it only supports those cars.
I was wondering if anyone knows for sure which one the 2012 Corvettes are using.
My guess would be that the 2012 would use the same tool that the other C6s use. I doubt they changed the vehicle CAN communications for 2012, so I don't know why the scan tool would change.
And as a related question, what's the best value tool to buy just to read and clear all codes on a 2012, including ABS and any other system? It'd also be nice to change the cooling fan temperature activation, but don't want to touch the ECU during warranty. Thx.
As to reading other modules (like the ABS), I believe someone said one of the units that Snap-On makes does, but almost no reader you can purchase that I know of for under $500 will read anything but the ECU (and maybe the Transmission controller). Less can do the bi-directional controls (like controlling the ABS to bleed the brakes).
Before spending $$$$ (and no I don't plan on purchasing a knock-off), I would like to know which one works. The MDI is significantly cheaper (hardware) than the Tech 2 (though probably because of the knock-offs or change to the MDI the Tech 2 appears to be dropping)
https://www.autoenginuity.com/products/scan-tool.html
From my 2010 GM Manual there are 2 data link types used.
1. High Speed GMLAN
2. Class 2
Depending on the module you wish to communicate with each have a design data link type.
eg. Body Control Module (BCM) uses High speed GM Lan
Passenger Door Module uses Class 2
I get the same results when I have connected to any C6 2010-2012 corvette.
This scan tool can read all the modules installed in my 2010 GS vert. Also includes bi-directional controls etc.
This may be a good alternative to a clone Tech2 and certainly a good choice vs a Tech2.
I have tested the unit by creating actual faults in my car by pulling fuses, disconnecting wires etc. It has reported the correct faults each time.
If you are interested I could show you more on this tool connected to my 2010 GS. This tool also allows you datalog while you drive. I have logged a few 1/4 mile passes to see what the engine is doing.
