Check engine light
Old Apr 25, 2012 | 02:01 PM
08LS36speed's Avatar
08LS36speed
8th Gear
Default Check engine light
Would a check engine light come on due to low power steering fluid? I have a small leak that doens't show to be to low on level ground. However the past times pulling up my drive and into the garage, the light comes on. The drive has a slight grade. Maybe the slight grade and turning the wheel sharp to turn into the garage?
Old Apr 25, 2012 | 02:06 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Get the code read. Tell me the number. I'll try and provide an answer.
Elmer
Old Apr 25, 2012 | 02:11 PM
08LS36speed
8th Gear
I was just curious if it could cause a code. I also had the dealer replace the oil pan gasket last week. If no one knows, I will have the shop run the code next week when the ECS blower goes on.
Old Apr 26, 2012 | 01:14 PM
EricT's Avatar
EricT
Elmer
Elmer,
Can a place like Autozone pull the codes even if my check engine light only comes on sometimes? Does it have to be on for them to read it or are they stored?
Regards, Eric
Old Apr 26, 2012 | 01:18 PM
eboggs_jkvl
Moderator emeritus
The ECM holds a record of the codes it sets. It maintains a history.
Elmer
To Check engine light
