doesnt wanna crank sometimes
Old May 1, 2012 | 03:59 PM
yellow05z51's Avatar
yellow05z51
Cruising
Default doesnt wanna crank sometimes
my car is 2005 c6 z51 18k miles...sometimes it doesnt wanna crank first couple tries..any ideas would be great ...stock xcept muffler delete kit.. 6sp..ive ran a few different fuel system cleaners through it and i only run 93 oct
Old May 1, 2012 | 04:12 PM
wildbadbill's Avatar
wildbadbill
do you mean it doesn't wanna crank, or doesn't wanna start/Because if it's cranking problem,than it's electrical,not fuel related..........
Old May 1, 2012 | 04:14 PM
yellow05z51
Cruising
like it will turn over i hit button down to turn off then most the time the 2nd time it will crank but sometimes it takes 3 times to start
Old May 1, 2012 | 04:27 PM
txvettefan's Avatar
txvettefan
Clean the chassie ground lug on the frame rail located beneth the battery and passenger side exhaust manifold. It is a 10mm deep well socket and you have a couple of large GM wire looms to work around. My 09 was doing the exact same thing.
Old May 1, 2012 | 04:28 PM
yellow05z51
Cruising
wow..gonna do that right now
Old May 1, 2012 | 04:29 PM
txvettefan's Avatar
txvettefan
It's the ground for your fuel pump.
To doesnt wanna crank sometimes
