Engine miss
Old May 2, 2012 | 12:32 AM
velocity yellow 2006's Avatar
Default Engine miss
My 2006 non zO6 car developed a multiple cylinder misfire while sitting at a traffic light. Just like someone flipped a switch. Car has 32k miles, A6 trans and a tune, no other mods. Engine is running very rich on fuel, disconnected battery but that did not help. Scanner only shows multiple cylinder misfire. Does not smooth out with rpm. Any suggestions? Thanks.
Old May 2, 2012 | 01:44 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need to get a scanner to read your DTCs. Thats the BEST way to figure out whats going on.. Otherwise,,,,,,, you will get 10000 guesses and that spells $$$$$$$$$$$$$$$$$$$$$$$$$
Read and post your DTCs
Bill
Old May 2, 2012 | 09:08 PM
The only code that comes up is a p0300, multiple cylinder misfire.
Old May 2, 2012 | 09:54 PM
ChevyDave's Avatar
ChevyDave
Read posts for their P0300 and suggestions...
http://forums.corvetteforum.com/c6-t...0300-help.html
http://forums.corvetteforum.com/c6-f...497-p0300.html
http://forums.corvetteforum.com/c6-t...815-codes.html
http://forums.corvetteforum.com/c6-t...t-misfire.html
plugs, plug wires, injectors, other listed in above. i like Elmers suggestion to start in total darkness, look for glows
Old May 2, 2012 | 11:58 PM
Redrocket1045's Avatar
Redrocket1045
I'm guessing a vacuum leak somewhere.
To Engine miss
