Corvette c6 FLOOD how to check engine? (Merged)
Old May 4, 2012 | 12:32 AM
deepbluesea6's Avatar
deepbluesea6
Default Corvette c6 FLOOD how to check engine? (Merged)
i got a c6 flood car, anyone know how i would check the engine for water etc...
could i take off the head?...etc?
i would like to see if theres water in the motor
Old May 4, 2012 | 12:38 AM
deepbluesea6
Default Corvette c6 FLOOD how to check engine??
i got a 07 c6 flood car, anyone know how i would check the engine for water etc...
Old May 4, 2012 | 01:01 AM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
Default ?
I don't have a clue -
but if it wee me I would
Take all the plugs out and drain the oil & filter -
Check the oil for water ?
Turn it over "manually" with the starter - check to see if water or
anything came out of the spark plug holes ?
good luck !
Old May 4, 2012 | 07:19 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
My guess would be to pull the plugs and try to turn over by hand. Should push out any water. Another thought would be to pull the plugs and use a scope to see inside the cylinders.
If you search the forum you will find posts on folks rebuilding C6 flood cars. They talk about the engine, replacing harnesses and other electrical components. Most of your questions will be answered in those posts.
Edit: I think you posted in one of those older threads. I guess you found them.
Salt water or fresh? How deep? Can you see a water line?
Old May 4, 2012 | 07:21 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
I read several flood C6 posts over the past few days. Are they giving these cars away? What is the appeal? Why a flood car?
Just wondering.
Old May 4, 2012 | 11:06 AM
Kenny94945's Avatar
Kenny94945
Remove intake, remove spark plugs.
Then turn over by hand.
Dropping the pan (if convenient is also a good choice).
Oil change....and good luck.
Old May 4, 2012 | 12:35 PM
lionelhutz's Avatar
lionelhutz
This is the submerged car?? Personally, I would disassemble completely unless you received it immediately after flooding and took action to clear out the water and protect the internals from water damage.
Old May 4, 2012 | 12:51 PM
deepbluesea6
yea i think fully submerged dont know how long id say a long time?? it was mudded everywhere but it didnt seem like salt water not 100% sure but besides taking spark plugs turnin motor by hand nothing?
Old May 4, 2012 | 03:04 PM
deepbluesea6
Also, no they are not iving them away if I had chance to do it again never would.
To Corvette c6 FLOOD how to check engine? (Merged)
