Question, when replacing end links....
Old May 8, 2012 | 06:13 PM
pittperson's Avatar
pittperson
Default Question, when replacing end links....
Does the suspension have to be unloaded or can I replace them with the car up on ramps?
Old May 8, 2012 | 06:17 PM
timd38's Avatar
timd38
You can do it on ramps. Just make sure that the bar is not in tension.
Old May 8, 2012 | 06:20 PM
pittperson's Avatar
pittperson
Ok, newbie question.... How do I know if the bar is in tension?
Old May 8, 2012 | 06:25 PM
Dan Wendling's Avatar
Dan Wendling
If you can wiggle the link then the bar is not in tension.
Basically the idea is to have the link slack.
Old May 8, 2012 | 06:32 PM
pittperson's Avatar
pittperson
Ah ok, I assume I have to remove the pillow blocks to test for wiggleness? ..... I just made that word up.
Old May 8, 2012 | 06:39 PM
haljensen's Avatar
haljensen
Drive on ramps will work fine. The only time an end link is under tension is when one wheel on the same axle is higher or lower than the other wheel on the same axle. The "sway bar" is actually a torsion spring and doesn't do anything as long as both wheels are moving the same amount in the same direction.
Old May 9, 2012 | 06:37 PM
Bill Dearborn's Avatar
Bill Dearborn
Do you have the new design end links from GM? Just had one replaced on my 08 and the new ones are steel and similar to the ones used on the C5s for a couple of years.
Bill
Old May 10, 2012 | 01:57 PM
pittperson's Avatar
pittperson
I had to old style that required the star bit, replaced those with the new style.
Old May 11, 2012 | 02:27 AM
jdwk's Avatar
jdwk
The wheels can be on ramps or both hanging freely. It is easier to work on them with the wheel off from the side though than under the car.
Old Jun 10, 2012 | 07:51 PM
child_of_fire's Avatar
child_of_fire
i have an 09 and want to replace the end links. couple questions...
why are stock ones $25 and LG motors wants $300 for the set?
specifically what size and type of tools do i need for this job? i see that the bolts and nuts are larger than what i have...
i will be doing this on ramps...
thanks
Old Jun 12, 2012 | 01:51 PM
el es tu's Avatar
el es tu
thanks
LG are different - heavier duty, adjustable, and teflon lined
regular hand tools - socket wrench and open end wrench
depending on the ramp, you may need to drive up on some boards first
Note: when installing you want to make sure they are as close to neutral as possible (not binding). If they are at a crazy angle while the car is resting on an even surface, then youll end up with the bars preloading during turns, which will cause handling issues.
Good luck - youll find that theyre super easy to do after youve gone through it once!
Old Jun 12, 2012 | 02:48 PM
victorf's Avatar
victorf
Longivity of teflon in endlink application is questionable, especially for street use!
Old Jun 12, 2012 | 03:42 PM
child_of_fire
thank you. but what size socket? i dont have one large enough i have to purchase...
Old Jun 13, 2012 | 07:42 AM
el es tu's Avatar
el es tu
not sure on the socket size - it varies between the different link kits and I believe lg has changed the bolts around a couple of times. I use a similar setup from a different brand. If you dont have that many sockets, you might as well buy a cheap kit. You can get most everything youll need for your whole car (in terms of sockets/wrenches) for less than 100 bucks - you might even get away with a 30 to 50 dollar tool kit if you go for a cheaper brand.
walmart and lowes have the cheaper brands. sears/craftsman stuff isnt too expensive, but you can get pretty good discounts on it through ace hardware, as theyre always having sales on craftsman tools. Sears also has a cheaper line called "evolv". While the cheaper tools may not be ideal for a professional mechanic or someone who does a lot of work, theyre fine for the occasional work while saving you from spending big bucks on snap-on or matco brand stuff.
Old Jun 13, 2012 | 01:17 PM
waddisme's Avatar
waddisme
My stock ones were 18 mm, but it seems like you need an open ended wrench for one side. If you are putting back stock links then I wouldn't think it would matter about preloading the bar as it will be what it is. If they are adj endlinks, then it would have to be pretty much neutral. I had mine up on ramps to get them adj with no preload. The rears you can reach without having to lift. I can't remember if I added weight to driver seat to allow for my fat butt or if that even matters with sways. Good luck with it.
Old Jun 16, 2012 | 09:01 PM
child_of_fire
i tightened the crap out of my stock end links with an 18mm wrench. still getting rattle/popping from the back. im not sure what else it could be...
Old Jun 16, 2012 | 09:16 PM
pittperson's Avatar
pittperson
Did you actually replace them with new endlinks or just tighten them? Its the endlinks themselves that make the noise.
Old Jun 17, 2012 | 09:04 AM
el es tu's Avatar
el es tu
worn endlinks will still work (not as well as they should though), but theyll make a clunking sound.
what you can do to test them (when everything is installed on the car) is carefully grab the bar near the link (or even the link itself) and trying to wiggle it up and down. if everything is tight, the bar wont move - if the link is loose youll get movement up and down and hear a click or clunk sound.
other sounds from the rear can be worn control arm bushings, worn or missing spring pad, lack of lubricant on the spring pad contact point(s), rear axle (loose nut(s) or corrosion to the splines and /or lack of lubrication to the splines).
hope this helps!
Old Jun 17, 2012 | 09:54 AM
child_of_fire
this would be covered under warranty, yes? ims still under 3yr/36mi. there is no play in the endlinks at all and i can't reproduce the sound while under the car. clunking is heard over rough road at slow speeds only.
To Question, when replacing end links....
