Thinking of bypassing clutch starter switch. Does it have any other function?
As far as the brakes, a very highly regarded single-pad covers A LOT less of the rotor than stock padlets, hence my comment that a CRITICAL system like brakes, I don't d*ck with that, since they were designed for padlets, not single pads. So I guess I should be the one confused, since you have no problem changing pads (nothing wrong with that, by the way), but get freaked out by a switch that doesn't prevent anything if you don't know how to drive a manual properly . Many people modify their cars for different reasons, and have different criteria for different modifications, from cosmetic, performance, or driving environment (tires, brake pads, etc). Don't try to play forum psychologist and expect the same criteria for every kind of mod. Just saying.
Finally, if I'm 'too confusing' for you, simply skip my posts and/or ignore me and problem solved . I already did the latter myself since you only seem to be looking to pick a fight, hijacking my thread. Have a good life man .
Received 2,061 Likes
The Studebaker President had both push-button ignition and a hill-holder as standard equipment clear back in 1936. Even though with only 115 HP there was no need for launch control, it was still considered a fine car at that time.
In my more than 50 years of driving I've owned a lot of different cars, but I've never owned one with an automatic - even my wife won't drive an automatic and it was hard finding a manual transmission mini-SUV for her!!
After millions of miles in manual transmission cars, trucks, and motorcycles, I just don't have a problem with disengaging the clutch to start a vehicle - with one exception!! When kickstarting my Harley Low Rider I needed to make sure it was in neutral because I couldn't pull the clutch lever in when jumping on it. However, I recently rebuilt it and put in a Primo 6-speed transmission. It does have the capability of installing a kickstart lever on it, but my exhaust covers up the area where it would go, so I'm just going to have to use the electric starter!
My main concern with your comments are that you put out info that forum members can work with - so what pads are you talking about? Regarding what you say in the quote above, I don't know what manufacturer's one piece pads you're talking about, but here is a picture of padlets on top of one piece pads - both are front pads:
In the picture above, at the top of the picture the padlets are on top of a Carbotech one piece (an early one that doesn't have holes in it for the 2 center pad pin bolts). The one at the bottom is a Hawk pad with padlets on top of it.
In both cases the padlets don't extend above or below the top or bottom edges of the one piece pad.
Notice how there is a lot of extra pad material on the one piece pads between the padlets. The hawk one piece pads are cut to a similar shape of the padlets, so the addtional pad material on the Hawk one piece is limited to between the padlets.
However, the Carbotech one piece has a smooth arc across the bottom and you can see that there is a lot of additional pad material.
So....for both the Hawk and Carbotech one piece pads, there is a LOT MORE pad material contacting the rotor to provide more torque for better stopping power than the padlets provide.
Again, I don't know what one piece pads you're talking about when you say "a very highly regarded single-pad covers A LOT less of the rotor than stock padlets", but all I know is that both the Hawk and Carbotech one piece pads have a lot MORE pad material in contact with the rotor.
Please tell us what one piece pad you're talking about so people can avoid using it, because I totally agree that you don't want to use something with less area than the padlets provide.
Bob
Just wondering if you did this mod already
I just need to know out of the three wires on the clutch switch which is the starter, cruise and ground
I think there are blue and green cables
If you accidentally bump the starter on a conventional key-switch ignition, you will reflexively flip back to the "run" position the instant the car lurches forward. This won't even be a conscious act. You'll notice a fraction of a second afterward that your wrist just did it.
On a C6, once you punch "start," the computer has complete control of the cranking duration. So you'd need to get on the clutch or pop the car out of gear, and/or really stand on the brake (w/o vacuum assist), and you'd have to think about it. This will take much longer.
Anyway, I realize the OP doesn't care, but somebody might.
