Air Lift
Old May 16, 2012 | 10:23 AM
Keith Tedford's Avatar
Keith Tedford
Default Air Lift
Does anyone make an air lift for the front suspension. It would be nice to be able to raise the front a couple of inches going into driveways and over speed bumps. As it is, the ants duck when I pass over them.
Old May 16, 2012 | 11:21 AM
EVRose's Avatar
EVRose
Don't know but that would be a pretty extreme mod to do just to go in and out of the driveway. If it's just the lower aid dam scraping it doesn't hurt anything.
Old May 16, 2012 | 11:48 AM
el es tu's Avatar
el es tu
Pratt and miller did it with a secial setup from arvin meritor. It added a ton of weight to the suspension though
Old May 16, 2012 | 12:01 PM
macguyver's Avatar
macguyver
scrapeing there is pretty common
Old May 16, 2012 | 12:54 PM
Keith Tedford
I've done a lot of looking on the internet and found nothing. Scrape it is I guess and thanks for the comments.
Old May 16, 2012 | 12:57 PM
PsychoB0B's Avatar
PsychoB0B
I'm sure with enough time and money the whole car could be outfitted with a ridetech suspension. Other than mounting the compressor/tank; its not much more involved than a coilover setup.
Old May 16, 2012 | 01:09 PM
el es tu's Avatar
el es tu
http://www.katechengines.com/street_..._12-07%291.pdf
article on the system
car is the C6 RS
EDIT:
More info http://prattmiller.com/news.php?NewsID=526
Old May 16, 2012 | 03:35 PM
taken19's Avatar
taken19
Track Junky
Just approach all bumps at an angle as it helps a bit. I take speed bumps at almost a 45* angle and I still scrape from time to time.
To Air Lift
