Possible bad battery??
Old May 17, 2012 | 02:01 PM
EVRose's Avatar
EVRose
Default Possible bad battery??
Battery is about 6 months old. I've never had starting problems or battery go dead for no apparent reason. Drove car one day fine, went out the next day and battery was totally dead - tested 4 volts and nothing was left on. I disconnected negative cable and put a charger on it. Went out an hour later and the charger was smoking hot, battery was not hot. Put cable back on and car started but a slight hesitation. Voltage reading on dic was 13.5. After driving 6 miles was still 13.5 - 13.6. Usually it's in the low 14s. Since the charger got super hot with battery disconnected from car this leads me to believe something wrong with the battery. Anyone have any input here what would cause the charger to get so hot? Thanks you.
Old May 17, 2012 | 02:38 PM
timd38's Avatar
timd38
Sounds like the battery has a short inside it, or got sulfated so bad that the charger could not break through it.
Old May 17, 2012 | 03:22 PM
m R g S r's Avatar
m R g S r
I'm surprised it got drained to 4 volts without major current draw. Must be a bad battery
Old May 17, 2012 | 03:29 PM
EVRose's Avatar
EVRose
I'm surprised too. When I put the meter on it I was expecting 9 or 10v but not 4. And it happened over night some how just sitting there. I don't get it.
Old May 17, 2012 | 03:32 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Get a new battery before you damage yoiur alternator!!!!! Should be under warranty!
What type of battery and where doid you get it from??
Old May 17, 2012 | 03:42 PM
EVRose's Avatar
EVRose
Originally Posted by victorf
QUOTE]
Saw your multiple post in different sections the past few days.
Checked your profile and you have an '05 and your issues with the harmonic damper.
You had your dealer replaced your harmonic damper and looks like you just got it back.....seems too much of an coincidence, maybe dealer inadvertantly drained your battery while it was there waiting!
Dealer R/R your damper, so its oem, we'll see how long the new replacement is going to last!
Actually this battery incident happened the day before I took it to the dealer for the HB replacement. The dealer just called and the car is ready. I'm waiting for someone from there to come pick me up to go get it. This battery problems has been on my mind the whole time. They never mentioned any starting problems yesterday or today when they contacted me to give updates. So we'll see what happens.
Old May 17, 2012 | 03:43 PM
EVRose's Avatar
EVRose
Diehard from Sears. I'm going to take it there and have them test it when I get the car back today.
To Possible bad battery??
