Pushrod length question? Help
Old May 25, 2012 | 12:53 PM
YELW 06 Z51's Avatar
YELW 06 Z51
Default Pushrod length question? Help
I want to make sure I'm in the ball park before getting pushrods.
I have LS7 lifters, .045 head gasket, not sure of the base cam height (i wish I would have measured it), milled TF 220 heads with 63cc.
I've measured and with the stock size pushrod and with that size it takes the lash out of the rocker.
I've also measured with the the comp cams checker and pretty much zero lash is taken out between 11 3/4 and 12 turns.
So this leaves me with needing a 7.450 push rod to get 0.50~.065 preload?
From what I've read there is no real answer where to have the preload set on the LS7 lifters. I've read from .030 to .100
It seems like most people are having to get smaller rods (7.3...) and I'm going the opposite way?
Is this sounding right?
Old May 25, 2012 | 01:50 PM
ITS STOCK's Avatar
ITS STOCK
Its really going to depend on the base circle of the cam you have in there now. I have a similar setup to you but with a stock gasket, but milled more than yours. My cams base circle is the same as stock and I ended up at 7.350 and it is pretty much dead on. If your base circle is smaller than stock than 7.450 could be correct.
Old May 25, 2012 | 04:41 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I am running 7.450 pushrods with a stock head gasket and milled TF 220's to 61cc. My cam is a comp grind
Old May 25, 2012 | 05:22 PM
YELW 06 Z51
I'm running a comp as well and I went through all the lifters and the majority of them came to 7.450. There was one odd ball that was measured at 7.454 but the lifter will take out that. A 7.450 will get me a .063 preload.
What are you running for PL on your lifters? Any sewing machine sounds?
thanks, Tristan
Old May 25, 2012 | 06:03 PM
Neumonic2002
I forgot to mention I am also running the LS7 lifters. Are you using stock rockers? I went with Yella Terra's and used the supplied shims (.040) my PL is right inline with your findings. My valvetrain gives off the sewing machine sound most common with the majority.
Old May 25, 2012 | 06:08 PM
YELW 06 Z51
The stock rockers are in. TEA put in powdered metal guides and mike said not to run shims with that setup.
Old May 25, 2012 | 06:13 PM
Neumonic2002
That is correct, shims are used with roller rockers to help dial in the geometry.
To Pushrod length question? Help
