Third tailight bulb replacement
Old Jun 12, 2012 | 02:02 PM
garyhunts's Avatar
garyhunts
Default Third tailight bulb replacement
My state inspection failed due to a faulty third taillight bulb being out. Is there anyone who can direct me as to how to replace this bulb without dismantling the entire rear end of the car?
Old Jun 12, 2012 | 02:26 PM
JoesC5's Avatar
JoesC5
You have to remove the two inner taillights. They are held in place with a single screw(torx) at the top. Just let then hang loose. If you're ****, wrap them with some old towels so they won't touch the paint. Then reach in with a 10mm box wrench and loosen the four nuts that hold the spoiler to the rear bumper. Normally, it only takes 1/4-1/2 turn to loosen and then they can be removed by hand. Just a suggestion...don't drop the nuts.
The spoiler will then lift straight up(normally there is some resistance as the studs will drag on the holes in the bumper). When you get the spoiler free( it will lift clear by 4-5 inches), you can then disconnect the electrical connector.
After you change the bulb, reverse the procedure.
Old Jun 12, 2012 | 07:19 PM
KENS80V's Avatar
KENS80V
The actual light is LED. So if any one section is not lit then you'll have to replace the complete unit.
Old Jun 12, 2012 | 07:41 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
It's a light assy, not a singular bulb
Old Jun 12, 2012 | 11:52 PM
JCtx's Avatar
JCtx
Hey OP, make sure to test your harness before buying a new assembly. You might have a bad connection or a blown assembly. Identify which one first. Good luck.
To Third tailight bulb replacement
