Please I need electrical help.
Old Jun 19, 2012 | 07:12 PM
360Rocket's Avatar
360Rocket
St. Jude Donor '12-'13-'14
Default Please I need electrical help.
So I came out to the car after work to a dead battery.
Got a jump, got the car running, no idiot lights, everything is running fine. Shut the car off and start it again, it turns over just fine. Got it to Advanced Auto and was told that the battery and alternator were fine. I ordered an Optima Red Top battery anyways. DIC says battery has at least a 12.9 volt charge and varies upwards to 14.2 volts.
BUT
Anytime that I open the drivers door, both rear view mirrors move to the down position, I am looking at the ground. AND the side windows are NOT rolling up to the full upright position.
WHAT THE HECK IS GOING ON?
Old Jun 19, 2012 | 07:35 PM
Vette_DD's Avatar
Vette_DD
Anytime the car battery is disconnected, then reconnected, you have to reset the window indexing.
Close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Don't forget the other window.
Normally, that's all that should need resetting, besides the clock, so I don't know what's causing the other things.
Old Jun 19, 2012 | 08:42 PM
360Rocket's Avatar
360Rocket
Thanks Jim. Im hoping that switching out the battery will fix the mirror issue.
Old Jun 20, 2012 | 10:31 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Reindex your windows and reset you MEMORY FUNCTIONS. Make sure that you gather ALL your FOBs and set the memory functions for all of them to the drivers pefered settings. All of this is in your owners manual
Old Jun 20, 2012 | 11:54 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Except I don't think you need to actually use the different fobs (well, you need one of them to start the car!), you can just push the memory 1 or memory 2 button on the door. At least, our 2009 3LT A6 seems to work that way.
Old Jun 20, 2012 | 02:46 PM
360Rocket's Avatar
360Rocket
Thanks gang, a new Optima battery and your helpful tips recitfied everything. THANK YOU ALL !!!!
Old Jun 20, 2012 | 02:51 PM
Vette_DD's Avatar
Vette_DD
Old Jun 20, 2012 | 08:59 PM
360Rocket's Avatar
360Rocket
So no power top? Does that have to be reset too? Geez !!!
Old Jun 20, 2012 | 09:04 PM
VET4LES's Avatar
VET4LES
Old Jun 21, 2012 | 09:25 PM
360Rocket's Avatar
360Rocket
Got home today, got in the car. power top starts to work. WTF?
Old Jun 22, 2012 | 07:59 AM
Justasheet's Avatar
Justasheet
When you reindex the windows that should fix your top.
Old Jun 22, 2012 | 10:24 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
(Jeff, are you guys heading over to Tower Shops tonight?)
Old Jun 22, 2012 | 10:43 AM
Justasheet's Avatar
Justasheet
Dave,
I wasn't planning on it but I just might. I'll let you know.
Jeff
To Please I need electrical help.
