Found this on my drainplug!!!!
Jun 20, 2012 | 10:23 AM
The car is a 2006 Z06 with 50k miles. The car is stock except for exhaust,halltech KB and tune. This was on my drain plug. Any ideas??
Jun 20, 2012 | 10:30 AM
St. Jude Donor '13
Woah. I have no idea what it is, but I'd be a little concerned for sure.
Jun 20, 2012 | 10:40 AM
Jun 20, 2012 | 10:46 AM
St. Jude Donor '07-'08-'09-'11-'12
Looks like a spring from one of your valve seals.
They wrap around the top as seen in this pic:
Quote:
Originally Posted by
66biskwik
Is that a spring?
Yes it is. I was thinking it might be a valve seal spring but I honestly have no idea. The car doesnt smoke or burn oil. I'm currently out of town, but as soon as I get back I plan to pull the plugs and check for oil residue on them.
Jun 20, 2012 | 10:50 AM
St. Jude Donor '11-'12-'13-'14
Yep, looks like a valve seal spring. I'd pull the valve covers and take a look to find the culprit.
Jun 20, 2012 | 11:04 AM
Holy cow man. Thank god for magnetic drain plugs.
Jun 20, 2012 | 11:39 AM
Well, it looks like the general consensus is valve seal. Ill get the valve covers pulled as soon as I get back in town. Thanks guys
Jun 20, 2012 | 12:30 PM
Easy fix if that's all it is. What are the bets it's an exhaust valve.
Jun 20, 2012 | 12:39 PM
St. Jude Donor '09
Craigster05
hahah i was sitting here thinking and came up with nothing.... GREAT call on the valve seal spring... I would have never thought of that. Thats deff what it is.
Jun 20, 2012 | 04:48 PM
Jun 20, 2012 | 05:48 PM
IrishC6
is that an aftermarket magnetic drain plug? or is the factory plug magnetic?
Jun 20, 2012 | 05:58 PM
C U IN REARVEIW
I purchased the car used and I'm not sure if the 06Z came with a magnetic plug or if it was added by the previous owner.
Jun 20, 2012 | 06:14 PM
I know it might be a PITA, but should I drop the pan to check for more debris? It might be overkill, but I would def feel better about it.
Jun 20, 2012 | 06:23 PM
I suspect it's time to check for excessive valve guide and valve stem wear, particularly on the exhaust side. When the valves start moving around a lot it has a tendency to tear up the seals. Make sure you also check all the springs.
Jun 21, 2012 | 02:31 AM
C U IN REARVEIW
My LS3 has an OEM magnetic plug.
Jun 21, 2012 | 03:57 AM
Ok...now you got me thinking!
I don't think my 08 Z comes with magnetic drain plug.
Jun 21, 2012 | 11:40 AM
986_C6
The ealry cars had the magnetic drain plugs. I think they changed to a non magnetic plug sometime within the 2008 run. My very early built 2009 Z06(built June 2008) did not have the magnetic drain plugs, so I went with the aftermarket ones on my first oil change.
Jun 21, 2012 | 01:10 PM
Have a may 06 car that did not come with a magnetic plug
Jun 21, 2012 | 01:15 PM
I just did my first oil change on my 2012 1LT, I don't think the plug is magentic. I should have picked one up before the oil change. Good call on the spring, I wouldn't have figured that out.
