615hp LS3 427 longblock
615hp LS3 427 - $7999 shipped!
LS3 blocks with bronze lifter bushings
Manley 4.100” stroke crankshaft
Scat 6.100” Rods (24X)
Eagle 6.100” Rods (58X)
Manley -7cc 4.068” bore flat top pistons
Ackerly moly rings
Clevite “H’ series rod and main bearings
Durabond cam bearings
SDPC custom roller cam 236/248 – 601/615 – 112
LS7 lifters
N-MOTION billet timing set
ARP cam bolts
LS2 front cover W/cam sensor
SD3964B ported oil pump
Assembled rear cover installed
LS2 valley cover (24X)
LS3 valley cover (58X)
Manley Pushrods
Stock rockers
LS3 CNC heads with PAC 1211X springs
24x engines include the necessary cam/knock sensor harness.
These are in stock and ready to ship immediately, no wait at all!
Jesse - (800)456-0211
If you have any questions feel free to give me a call.
any chance for a little more head work and cam to squeeze out a little more power???
also im assuming the 615 horses are with the stock manifolds, intakes???
also what would you say about running E85 on this motor???
thanks
IF that is the case here - which I suspect given the application towards hot rods in general - then I would expect noticeably less HP from our more restrictive intakes.
I'd love to estimate rwhp for you guys but it can vary so much car to car and dyno to dyno that it's not fair to try to do so. The most recent installation at an independent third party shop made 520rwhp in an automatic C5 (3200 converter).
Whileas I can not guarantee rwhp results, I can guarantee that the 615hp claim is honest and utilizes no tricks.
thanks
You'll definitely be on my short list, should I ever need a new motor... Lol.
