Old Feb 20, 2015, 06:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
2005 auto transmission problem
Old Jun 24, 2012 | 10:04 PM
trplblk's Avatar
trplblk
Default 2005 auto transmission problem
Ive just bought a 2005 covertible and it just completely dropped 3rd gear. It shifts fine from first to second, but as soon as it trys to shift to 3rd it does nothing but finally shifts to 4th and all is fine after that. could this be the 3-4 servo out? or am I lookig at another complete rebuild? any help would be great. If I need a trans, what should I get? new to vettes but wanted one for 10 years. Thanks,
Old Jun 25, 2012 | 10:43 AM
cartwheel's Avatar
cartwheel
More info would be nice. Is it throwing a code? Is the car stock?
Old Jun 25, 2012 | 10:59 AM
trplblk's Avatar
trplblk
No codes, Car has aftermarket heads, new exhaust with no cats. vaaram, pretty much it. car is just at 450HP +/-
Old Jun 25, 2012 | 12:01 PM
Tikiman12's Avatar
Tikiman12
video it for us to look at and hear, there might just be a really funny tune on the car
Old Jun 25, 2012 | 12:41 PM
cartwheel's Avatar
cartwheel
It could just be the 3rd/4th gear solenoid. If it fails electronically it should set off a fault. However if it fails mechanically it may not. If I remember right. I believe if it is stuck open it won't allow 3rd gear but may allow 4th gear like yours is doing.
Old Jul 7, 2012 | 08:30 PM
SamBouez's Avatar
SamBouez
Cruising
Hello trplblk, weird coincidence, I have the EXACT same problem on my 2005 coupe, and it started on 29/6/2012 (10 days ago). I've had mine for 4 months, and only 30k miles on it. Did you solve your problem yet? Detailed feedback greatly appreciated, as I risk spending 6400$ on a new transmission next week.
Old Jul 7, 2012 | 08:44 PM
trplblk's Avatar
trplblk
No I haven't I haven't had time to take it to a
Reputable place yet. I would
Bet that with
My luck it will be need totally rebuilt. Good luck with yours. And let me know what
You find out please. Thanks
SamBouez's Avatar
SamBouez
Cruising
Hello cartwheel, excuse my ignorance in car mechanics, where exactly is the solenoid located? Can it be replaced?
I wish I could prepare a video but the car's already in the shop. Basically the automatic transmission shifts normally from 1st to 2nd gear, then at about 28mph the gearbox "slips" completely, if I step more on the gas paddle, RPM rises but the gear seems disengaged, though the car somehow gains speed very very slowly, eventually it abruptly moves into 4th gear when speed is close to 43mph I believe.
Last edited by SamBouez; Jul 7, 2012 at 08:47 PM. Reason: I specified more details in the last line.
Old Jul 7, 2012 | 09:00 PM
SamBouez's Avatar
SamBouez
Cruising
Bet that with
Unfortunately my friend, I'm in Lebanon (Middle East), no pro garages here, not even the sole dealer garage who advised me to install a brand new transmission.
Have a look at this thread, it could be relevant to our problem:
http://forums.corvetteforum.com/kens...-problems.html
Old Jul 8, 2012 | 10:30 AM
SamBouez's Avatar
SamBouez
Cruising
Hello, can someone please provide the details of the following TSB ?
Make : CHEVROLET Model : CORVETTE Year : 2005
Manufacturer : GENERAL MOTORS LLC
Service Bulletin Number : 3451
NHTSA Item Number : 10017007
Component : POWER TRAIN
Summary :
SLIP CONDITION IN 2ND 3RD OR 4TH DAMAGED 2-4 BAND 3-4 CLUTCH. 2005 ALL FULL-SIZED TRUCKS AND UTILITIES/2005 ALL MID-SIZED TRUCKS AND UTILITIES *SC
Old Jul 8, 2012 | 10:38 AM
dennis50nj's Avatar
dennis50nj
when mine did it back in 2006-7 it was a tsb ms-machined case, fine aluminum particles were clogging the screens in the noids . the replaced it several times finally the tech put the long bolts wear the short ones go into the sun gear opening and ruined the trans
Old Jul 14, 2012 | 10:51 PM
trplblk's Avatar
trplblk
Default Trans
Now it's gone completely. Going
To load it on a truck today and it went out cpletely without any warning. I don't get it. 15 mph. Then Rpms started to rise then car slowed to a halt and would not move in any gear. Does this sound like clogging screens or what. Gm will get it next week when I have time but I'd like to
See if anyone has other ideas first.
Old Jul 15, 2012 | 05:47 AM
SamBouez's Avatar
SamBouez
Cruising
My car's currently in the garage undergoing a transmission rebuild, but only for 3rd gear. The mechanic also ordered a "mod package" for the 3rd gear, which will eradicate this issue and prevent it from happening again. Apparently, the 2005 4-speed transmission suffers from a lot of strain and overheating, this might be why it was replaced with a 6-speed the following year.
Old Jul 15, 2012 | 03:41 PM
KB9GKC's Avatar
KB9GKC
I've seen the whole auto 6 speed auto transmission brand new for $2000 on Ebay.
Douglas in Green Bay
To 2005 auto transmission problem
