Header Question
Old Jun 25, 2012 | 02:13 PM
jost6453's Avatar
jost6453
Default Header Question
I'm thinking of making a few performance upgrades to my '11 GS coupe (6spd manual) with the goal of increasing low rpm torque and achieving 500+ hp. The plan includes adding the Halltech Beehive air induction, a slightly hotter cam, headers, and a tune. But I'd perfer to NOT cut the factory NPP exhaust.
So the question is this: Are there headers out there that replace the stock factory manifolds without modification to the exhaust system .... and what is the performance difference between the short tube vs. long tube designs?
Old Jun 25, 2012 | 03:16 PM
Shifter6's Avatar
Shifter6
The big gains from long tubes happen in the middle of the powerband. This is due to the longer primary runners. A short tube header is a compromise and will be an improvement but not offer the typical gains of a full long tube.
The idea behind the longer primary runner is to take advantage of the scavaging effect at a more usable RPM. Factory manifolds actually dont flow that bad, but their ultra short runners offer no scavaging ability at any usable rpm.
Bottom line, if you are going for headers you might as well go full length. However if you stay with the factory mainfolds and cats it will be difficult to reach your power goals.
Old Jun 25, 2012 | 07:53 PM
kmthor00's Avatar
kmthor00
Kooks headers & off road pipe going on tomorrow, just dropped car off, keeping NPP exhaust. Won't be 500 but I'm ok with it right now, good luck with your goals.
Old Jun 26, 2012 | 03:04 AM
macklinvinger's Avatar
macklinvinger
Cruising
yes u are right
Old Jun 26, 2012 | 07:06 AM
mattdracing's Avatar
mattdracing
i have a '12 GS 6 speed manual. i just did kooks 1 3/4 headers with offroad x pipe, K&N CAI, and tune. I still have my NPP exhaust. First off....its sounds amazing with the valves open! i have a mild to wild switch but i leave them open 99.9% of the time
It definitely has quite a bit more power. plenty for me. if you do a pretty big cam like the LG G6x3 cam you will make near 500whp but you will lose some driveability with that big cam. with a mild cam u can make roughly 440whp or so. or you can bolt on a supercharger and make a ton of power and retain stock driveability haha
Old Jun 26, 2012 | 08:28 AM
EVL JAKE's Avatar
EVL JAKE
St. Jude Donor '12-'13
Pretty much any header system for the C6 uses the stock axle back (mufflers) unless otherwise specified. You get long tube headers and an intermediate pipe that the mufflers slide into. You still retain the factory npp. Currently I have TSP long tubes with a catless intermediate connected to the factory mufflers.
Old Jun 26, 2012 | 08:58 AM
j_digi454's Avatar
j_digi454
I have the long tube ARHeaders with 3" x-pipe & hi-flow cats that connect to the stock 2 1/2" NPP axle back exhaust that I added previously.
Old Jun 26, 2012 | 10:19 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
We have had a few C6's hit 500 rwhp with a medium sized cam. They drive great and sound bad ***. With the Headers, that is a 25 rwhp gain before tuning. After tuning, expect another 10 rwhp. With the CAI added, most M6's are over 430 rwhp after tuning. The gains are throughout the entire rpm band and the LS3 loves bolt-ons.
Old Jun 26, 2012 | 01:44 PM
jost6453's Avatar
jost6453
Thanks for the input. I guess long tubes are the way to go. I can't seem to find any 'shorties' anyway.
Old Jun 26, 2012 | 02:03 PM
fnbrowning's Avatar
fnbrowning
jost6453;
It is true that you can generally expect a 25 rwhp gain before tuning with the headers, and another 10 rwhp after tuning. But I will say that extra 40+ horse you want from the cam + another tune is not going to net you a mild-mannered beast.
What the tuners don't tell you is that you'll be married to the optimium tune for your city. They will have used up all the octane & spark advance margins GM programmed into the PCM, and beware if you drive out-of-town and get a substandard load of gas or you're on a hwy grade on a hot day because the engine will be knocking.
Old Jun 26, 2012 | 02:16 PM
EVL JAKE's Avatar
EVL JAKE
Originally Posted by fnbrowning
jost6453;
This is completely inaccurate. No matter what parameters are changed in the tune your car still has a MAF, knock and O2 sensor. Your PCM will adjust your fuel tables. The tune merely optimizes the air/fuel for your mods. If you put headers on a car and don't tune it the sensors will compensate so you don't melt your engine. A tune adds more fuel and spark advance to optimize the increase in exhaust scavenging. If you get a bad tank of gas or drive in high altitude the PCM will make adjustment to protect the engine. You won't have optimum performance but the same will happen to a stock tuned car.
Old Jun 27, 2012 | 11:46 AM
fnbrowning's Avatar
fnbrowning
You are not being completely accurate.
If you're going demand a high HP number from a few simple bolt-on's the tuner is going to jack around with the PE tables and commanded A/F ratio, and timing so on the dyno, it shows a power increase.
They can't hit a high artificial HP number & care about protecting for things like driving up Baker grade at 70mph in the desert heat and not allow anything to overheat, knock, or otherwise fail. GM's left maybe 5% on the table without compromising on the longevity of the life of the engine.
With a "slightly hotter cam, headers," and a realistic tune, you're going to see an increase, but not to 500HP, and if you try it, you're chipping away the longevity of your engine.
Old Jun 27, 2012 | 12:01 PM
EVL JAKE's Avatar
EVL JAKE
By putting a higher lift cam in a vehicle you're sacrificing longevity of the valve trains. Does that mean that the car won't go 100K miles? Nope. You may sacrifice some longevity but every day wear and tear is different on any vehicle. Going up a steep grade in 100 degree heat is going to take it's toll on a totally stock car. Portraying that because you have a tuned car you have to only drive it in you neighborhood is ludicrous. I have always had dyno tunes and bolt-on's done to my cars. I drive them any where in any conditions including high altitude and extreme heat. My knock sensors are enabled and I have never toasted a motor.
Old Jun 27, 2012 | 03:00 PM
fnbrowning's Avatar
fnbrowning
Totally missed the points, probably on purpose. Actually deliberately misread several points, and finished with an I/me declaration with a blind statement that if YOU"VE never seen a problem, no problem can ever exist. That's not discussing, that's just quarreling.
Old Jun 27, 2012 | 03:12 PM
EVL JAKE's Avatar
EVL JAKE
Not quarreling at all, just trying to make the OP aware that you posted inaccurate information that should be disregarded.
A dyno tune by no means "marries" you to "your city". Parameters can be taken to limit but the PCM still does it's job as designed to protect the engine. I just can't stand when somebody posts blatantly wrong information on a forum in response to somebody who doesn't understand the topic fully. I would hate to see a person be turned off to modifying a car because of the BS you posted. 500HP can be made, it has been by several different shops. Dyno's vary, that doesn't mean that the tune is maxed out and is dangerous.
Old Jun 27, 2012 | 05:17 PM
fnbrowning's Avatar
fnbrowning
You are posting misleading information and the OP should be made aware. You deliberately misread my post to stipulate that 500HP can be made with the parts the OP listed without compromise.
Most stock LS3's make about 370-something rwhp on the average DynoJet on average weather days. To post 500HP reliably, with headers, cam & tune (in the real world were people are not mislead,) that's going to be more than mild cam timing and headers. I'm saying wilder cam timing, and an agressive tune.
Read: The OP is not going to have a mild-mannered car, there will be some compromises in drivability and or reliability.
Old Jun 28, 2012 | 11:27 PM
TSLAVette's Avatar
TSLAVette
Oh boy ... I like pie!
To Header Question
Old Jun 29, 2012 | 08:02 AM
jost6453's Avatar
jost6453
I appreciate the lively debate, but I'm afraid I was not very clear describing the goal. The GS is rated at 436 hp. I 'm considering mods that would take that number to ~ 500hp .... so ~ 65 hp gain. I had not intended to go for 500 rwhp performance. So with that being clarified, can I get there (or close) with a Halltech Beehive, long tube headers, & a tune?
Old Jul 25, 2012 | 01:34 PM
MikeinAZ's Avatar
MikeinAZ
I just had Kooks headers and X pipe w/ cats installed and retuned. I already had the Corsa Sports on and a Blackwing CAI and tune. I was at 396hp to the wheels last year when I had those mods dynoed and on my baseline run the other day I had the same hp on a different dyno, different shop. After the install of the headers and X pipe and retune I had 458hp to the wheels. I could not be happier w/ the great sound and the performance gain. The engine spins up so much faster and you can really feel the difference. I was a little surprised at how much of a gain in hp we got, the LS3 does love the boltons, I wish I had done this sooner.
Old Jul 25, 2012 | 04:28 PM
EVL JAKE's Avatar
EVL JAKE
Yes. My LS3 5th gen Camaro made 423 rwhp with intake, tune and headers. That comes out to right around 500 bhp. The Vette should do the same if not a little more.
