HUD Install Question
Old Jun 26, 2012 | 06:25 PM
BadgeZ28's Avatar
BadgeZ28
Default HUD Install Question
I am using the cut the air duct method. I have cut the duct and removed the fastener next to the dash output. there is another bracket at the back I can't seem to release. I can see the bracket, but can figure out how to remove it. How do you remove that back connection? Thanks
Old Jun 26, 2012 | 10:27 PM
BadgeZ28's Avatar
BadgeZ28
I found an older thread and the guy doing his install said to just break it off. Guess that is the easiest way.
Old Jun 26, 2012 | 10:29 PM
swvalleyguy's Avatar
swvalleyguy
I have done 2 perfect installs without cutting duct just shoehorned in maybe if patient you wont have to remove bracket.
Old Jun 26, 2012 | 11:57 PM
JSB LS3's Avatar
JSB LS3
I did it this way and it worked fine. The one bolt on the left plus the aluminum tape to close the cut method made the duct rock solid when I put it back in.
Old Jun 27, 2012 | 02:03 AM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
Use the Force!
Old Jun 27, 2012 | 01:04 PM
BadgeZ28's Avatar
BadgeZ28
Good to know. that was my major concern eliminating that mounting point. Thanks
Old Jun 27, 2012 | 01:17 PM
Former Vendor
it's still going to be bolted in and will also have the HVAC tape on it. Also don't forget that it's PITA to even get it back in even with cutting it. It'll be a tight tight fit.
Old Jun 28, 2012 | 05:42 PM
WHT's Avatar
WHT
IMO, you made the most interesting post. Care to comment on your procedure? Thanks for any information.
Old Jun 28, 2012 | 05:59 PM
Former Vendor
I think he's referring to loosening the dash and then trying to shoe horn the projector in.
To HUD Install Question
