Instant MPG accuracy check
Old Jul 2, 2012 | 10:11 PM
HOXXOH.com's Avatar
0HOXXOH.com
Former Vendor
Default Instant MPG accuracy check
I headed South toward the border today and while I was down there having fun, I thought I'd better check my MPG reading, in case I needed gas before I got back home.
Kinda give me a little slack for the pic quality. Those damn Mexican roads aren't real smooth.
So does this look about right with the cruise control on? I was expecting a little more at only 3000 RPM.
Yeah, the airbag light is still on.
Old Jul 2, 2012 | 10:21 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
i do that all the time on jackstands. :wink:
Old Jul 2, 2012 | 10:30 PM
HOXXOH's Avatar
HOXXOH
That'd bother me on jackstands. Like Ferris Bueller's day off.
So just curious now, what does the DIC read on jackstands?
Old Jul 2, 2012 | 11:25 PM
torquetube's Avatar
torquetube
I'm sure you'd have to turn T/C off or else it the motor would just bog. I assume the speedo is reporting information from the front wheel speed sensors, so your instant fuel economy should read 0mpg.
Old Jul 3, 2012 | 12:05 AM
HOXXOH's Avatar
HOXXOH
I can assure you this was on the road. While it's possible on jackstands or even on a dyno, the mpg would be a lot higher. It's necessary to have TC off to do a burnout, but the speedometer registers the speed at the transmission. AH needs to know the speed of each wheel independently.
I'm just trying to see the real world relationship of the aerodynamics to the mileage as the speed increases.
Old Jul 3, 2012 | 07:31 AM
Travelor's Avatar
Travelor
Getting 12 MPG at 140 mph really is not bad.
My thought is your posting was a bit tongue-in-cheek due to the high speed at which you were going.
George
Old Jul 3, 2012 | 08:07 AM
Justasheet's Avatar
Justasheet
Old Jul 3, 2012 | 08:38 AM
TLTONEY's Avatar
TLTONEY
Is that dust I see??
For shame!
Old Jul 3, 2012 | 08:59 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I've noticed my airbag light comes on as well at 130.
This was done on an airstrip rental.
I should have had my instant MPG on the DIC..that would have been interesting!
I can say, since I track each tank of fuel, that particular tank, with 3 180+ runs and a drag strip run on the way home, got 16.34 mpg (including the long drive to/from the air strip) vs. my average at that time of around 19 or so.
I have one tank that I burned completely at Sebring when the car was bone stock, that tank was 8.37 MPG!
Old Jul 3, 2012 | 08:37 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
While driving along a really flat, straight, deserted road in Florida; I did multiple tests of the mpg at 40, 60, 80 mph. That was on our 2006 and I don't have the numbers any more, but there was a big dropoff in mpg even from 40 to 80.
Old Jul 3, 2012 | 09:30 PM
carlrx7's Avatar
carlrx7
maybe its because an airbag isn't going to save your life in the event of a crash at over 130. or could be the constant g force on the seat sensors.
-Carl
Old Jul 4, 2012 | 12:39 AM
ROD BROWN's Avatar
ROD BROWN
Default 2009
My 09 with the Z51 pkg. averages 13.0 MPG.That's a combination of city and freeway driving.I don't drive my car hard,but the MPG isn't that good.My 06 got 16 MPG average city and freeway griving.Oh well I guess I'll grin and bare it.
Old Jul 4, 2012 | 02:24 AM
lemgomez's Avatar
lemgomez
I usually average low 20's, averaged 30.1 on a 2500 mile trip i just took (with average speed of 73.5 mph, one tank was 37mpg average (Going up and over the cont divide at 80mph, this car seems to like high alt)
Old Jul 4, 2012 | 04:50 PM
HC Mechanic's Avatar
HC Mechanic
I found my instant MPG to read 2 MPG high over the course of 2000 mi.
Tire sizes probably have a bit to do with it...I saw 30 MPG on the DIC for most of the trip. Fuel reciepts reported 28 MPG, with an 80mph ave. speed.
Old Jul 4, 2012 | 05:10 PM
BLKCLOUD's Avatar
BLKCLOUD
Yup, my DIC average MPG is consistently .75-1.0 MPG optimistic. I keep pretty good records.
Car is a stock 2010.
Old Jul 7, 2012 | 12:29 PM
torquetube's Avatar
torquetube
Oh of course, they are still using the sender at the gearbox. At some point I suspect they won't; one fewer hole to drill.
Old Jul 7, 2012 | 01:04 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Actually the VSS reads off a reluctor wheel on the ring gear. It's accessed on the top of the diff.
Here's my expanded diff view, it's on the top.
Old Jul 7, 2012 | 05:15 PM
Gearhead Jim
St. Jude Donor '13
Nice choice of words!
To Instant MPG accuracy check
