what are basic maintenance
Old Jul 3, 2012 | 09:41 AM
Onenastyvette's Avatar
Onenastyvette
Default what are basic maintenance
Hey guy's , i just purchased my first 2005 vette. i purchased the car with 52,000 miles from a used car dealer. The car is stock 6spd. What are the basic maintenance things i should be doing to my car with this mileage?
Thanks for you input..
Old Jul 3, 2012 | 10:52 AM
trebor8008's Avatar
trebor8008
Check the clutch fluid, if it's dark change it. Do a search on here "Ranger Method" This works great, it's easy and inexpensive.
Old Jul 3, 2012 | 11:19 AM
Onenastyvette
Ok cool , thanks
Old Jul 3, 2012 | 11:52 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
If you don't have a record of its service history, I'd suggest replacing the engine oil along with the transmission and differential fluid. This will give you a clean slate to start from.
Old Jul 3, 2012 | 12:48 PM
AmmoVet's Avatar
AmmoVet
Above plus brake, coolant, and power steering fluids, all easy to do your self.
Happy 4th!
Old Jul 3, 2012 | 12:57 PM
Don 79 TA's Avatar
Don 79 TA
do all fluids, heat is a killer to them
and air filter, cabin filter, and spark plugs while you're at it
for the brakes, if you don't want to bleed them, get a like a baster to suck out the res
can also use that for the clutch and PS too
take out the overflow tank and give that a good cleaning too
Old Jul 3, 2012 | 05:11 PM
CroOrange's Avatar
CroOrange
Sparks at 50k, really?
Old Jul 3, 2012 | 05:15 PM
torquetube's Avatar
torquetube
I would. Changed mine at nearly 60K and light-throttle smoothness definitely improved.
Old Jul 3, 2012 | 08:18 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I had the dealer change our C5 plugs at ~50k miles, and the tech said they didn't really need to be changed. But he said the ones he changes at ~100k miles definitely do need to be changed.
Old Jul 4, 2012 | 10:25 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Be very careful about changing plugs. Make sure you get the right ones for the car and I strongly suggest using the same as OEM or close to it. I made the mistake of spending for high-dollar NGK's thinking better plugs than OEM. Error...Malfunction...caused me charge system faults and yes, its true. Noisy plugs will cause charge problems....that's electrically noisy.
Old Jul 4, 2012 | 11:29 AM
kmthor00's Avatar
kmthor00
FYI, 2005 is a 4 speed tranny
Old Jul 4, 2012 | 04:18 PM
Dragracer_Art's Avatar
Dragracer_Art
The automatic, yes. The manual is a 6-speed.
Old Jul 4, 2012 | 10:29 PM
Boomer111's Avatar
Boomer111
I am big on fluid changes. Usually change at least by 50% required interval. I like keep the fluids as fresh as convenient for me which is yearly for most and at least every two years for trans, with yearly diff changes. Coolant I go 3 years with under 15,000 miles driven.
I also am coming up on almost 2 years of not washing the Vette, so maybe I am not the right person giving advice to follow....
Old Jul 4, 2012 | 10:57 PM
Bill Dearborn's Avatar
Bill Dearborn
I haven't changed plugs in over 17 years since I only keep my cars for 6 years or so and they never get enough mileage to justify changing the plugs. The only exception is my 03 Tahoe which is pushing 90K miles with a fair amount of trailer towing and the gas mileage seems to be dropping so it might be time to look at the plugs.
To the OP, if you didn't get an owner's manual go to the GM Parts House web site and click on the Downloads link and get a PDF version. All the answers to your questions are there.
Bill
Old Jul 4, 2012 | 10:59 PM
Bill Dearborn
Might have gotten the same improvement by just removing the plug wires and pushing them back on.
Bill
To what are basic maintenance
