OK I'm a new Vette owner and have a 08 with z51 and it's a manual. My questions is if i want to come close to the posted 0-60 numbers (4.3sec) what gear shift do I need and what RPM should I shift at?
You don't have to shift at all. Can do 60 in first gear.
Your Z06 has the same rear axle ratio and gear ratios as the non-Z51 C6, but his engine is redlined at 6500 RPM, yours is redlined at 7000 RPM. That extra 500 RPM on your car gets you to 60 MPH in 1st gear.
