Mod plans to reach 400whp
Old Jul 18, 2012 | 05:27 PM
jeffinavette's Avatar
jeffinavette
Default Mod plans to reach 400whp
Hey guys i'm looking to make 400whp with my bolt on's that im planning to purchase. I've done a little research on here but i'm willing to see what you guys think and am open for discussion/suggestions. 07 LS2 A6 car here.
-Vararam Snake Charmer
-Fast 102 Ported
-160 Tstat
-OBX Headers
-LG Axle Back Exhaust
-Tune
Stock converter, stock heads, stock cam
I want to make 400 with just bolt on's before going to the SC later on down the road.
Old Jul 18, 2012 | 05:45 PM
Snug's Avatar
Snug
That doesn't sound unreasonable since my 06 LS2 is making 381rwhp with Kooks headers, Borla exhaust, and a tune.
Old Jul 19, 2012 | 09:22 AM
CWHPARTS's Avatar
CWHPARTS
Platinum Supporting Dealership
are you a auto or manual?
to the op you will be close
on mine i did 160 thermo, unported fast 102, halltech mf103, lg 1 3/4'' headers (no cats), flowmasters and it made 395 rwhp (sae) but mine is a manual auto lose more power through the drivetrain.
__________________
YOUR CORVETTE SUPERSTORE SINCE 1988
CORVETTE WORLD HOUSTON
281-821-1222
http://corvetteworldhouston.com/
Old Jul 19, 2012 | 10:10 AM
FloydSummerOf68's Avatar
FloydSummerOf68
You'll need an underdrive pulley to try and hit 400rwhp on an A6 LS2.
I put down 397 with Ported FAST, Catless longtubes, intake and 25% UD pulley
Old Jul 19, 2012 | 10:37 AM
ricefed's Avatar
ricefed
MI Events Coordinator
Don't waste money on all that. Just get a sc and blow the 400 away. You won't use the VRAM with a sc and the intake won't get you anything extra with a sc. My 07 was bone stock added the A&A sc and put down 546 rwhp.
Old Jul 21, 2012 | 01:22 AM
Gering's Avatar
Gering
Tolero Apto Victum
OP: We have the same car, 07 A6. Take a look at my mods list for some ideas. I am making 433 RWHP & 413 RWTQ. I also have over 135,000 miles on it and still running strong.
Old Jul 21, 2012 | 08:55 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
We did an install on a 05 LS2 A4 and put down 573 rwhp on a stock Vette. The Vararam and FAST 102 are not needed and makes a down payment on a blower. The FAST Intakes bring some new problems if you will be installing the SC.
The FAST Intakes are an inch longer and pushes the TB forward 1 inch. That causes the TB motor not to sit in the SC bracket as designed. The TB has to be flipped 180 degrees and you need a TB extension harness from Caspers. Now that the TB Motor is on the driver side, it hits the power steering reservoir. The lower hose needs extended from the reservoir to the pump, 5/8" heater hose. Also, the reservoir will need shimmed by 1" to clear the TB Motor. The spacers that come with the Katech Tensioner are a perfect length for shimming the PS reservoir. With the FAST 102, it is a good idea to use the Hinson Motor Mount and drop the engine by 1/3" to allow better clearance between the cowl and intake.
Old Jul 21, 2012 | 09:33 AM
mattdracing's Avatar
mattdracing
i have an LS3 with full bolt ons/tune and it pulls pretty decent but not near enough for me. im gonna go forced induction when i can =) from stock to bolt ons...its a noticeable difference but nothing that will blow you away at all.
Old Jul 21, 2012 | 10:12 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Especially for the money spent........stock to bolt-on only.
Old Jul 21, 2012 | 05:49 PM
FloydSummerOf68
If I were doing it all over again I'd just straight to an A&A kit (which I now have)
To Mod plans to reach 400whp
