Catch Can Works
Old Jul 19, 2012 | 10:19 AM
C7cmnthru's Avatar
C7cmnthru
Default Catch Can Works
Put a catch can (CCA version) on at about 6K miles, now have about 26K. Hadn't drained it before since I didn't think I would be passing that much oil. Not S/C'd or turbo'd and don't race. Anyway, had to remove it to replace the evap emissions purge valve solendoid so I thought I would drain it. I was surprised at what came out. about 6 oz of oil.
[IMG][/IMG]
Old Jul 19, 2012 | 12:49 PM
Don 79 TA's Avatar
Don 79 TA
i liked the elite engineering one so much that i put on the wifes 05 i bought one for my TA
it has been EXTREMELY benefical for my TA, especially with the BS baffeled valve covers and valley cover i have now
Old Jul 24, 2012 | 09:26 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Six oz of oil in 20k miles equals about one quart per 100,000 miles. That does not seem like a lot to me, our 2001 burned (no leaks, it all went through the engine) a qt every 3k-4k miles and was still doing fine when traded at 66k miles.
Old Jul 24, 2012 | 11:43 PM
msd127's Avatar
msd127
I have one on my Z, works well glad I bought it.
Old Jul 25, 2012 | 02:45 AM
X25's Avatar
X25
Sr.Random input generator
Burning in the engine and puking it to the air intake are two very different things in my opinion
Still, I installed one to my car as well since it is very easy, but I don't think it's that important, either.
Old Jul 25, 2012 | 01:49 PM
victorf's Avatar
victorf
Unless motor is disassembled and verified, can't make assumption that motor still doing fine without proactive action taken! Performance deterioration is gradual, can't be felt unless you are extremely sensitive and cumulative built up will surly affect performance with high mileage!
But I can guarantee in your situation, that you had suffered varnish built up in intake manifold, carbon/varnish in back of valves/valve stems, combustion chambers and piston tops with your 66k miles trade in!
Take an engine or two apart, then you can speak with authority pal!
Old Jul 25, 2012 | 04:40 PM
Gearhead Jim
St. Jude Donor '13
So far, the C5's I'm familiar with that are burning oil (mostly 2001's with the "improved" rings) are still doing well at over 100k miles. But I agree, that burning oil inside the engine is never a good thing.
My point was that reducing oil "burn" by 1 qt/100,000 miles is not likely to make a lot of difference.
Old Jul 25, 2012 | 06:34 PM
victorf's Avatar
victorf
I am super **** in details, personally, that 1 qt/100,000 miles is definitely 1 qt/100,000 miles I can do without! Particularly, if the ingestion can be simply diverted.
To each his own Jim, I am only expressing my opinion, its all good!
Old Jul 25, 2012 | 10:46 PM
midgetracr's Avatar
midgetracr
To me the issue is not having to add oil or burning a quart in 100K miles.
The issue is the reduced octane of fuel that results from the oil mixing with fuel at high throttle openings. Also, I have observed puddles of oil in the low spots of the ports in LS intake manifolds. Those puddles change the port shape, and presumably the air flow thru the ports.
Both of the above will affect performance.
Old Jul 26, 2012 | 01:57 PM
Gearhead Jim
St. Jude Donor '13
I am super **** in details...
In other words, a typical Corvette owner. Just like me.
We simply pick different things to fret about.
Old Jul 26, 2012 | 02:55 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
It's definitely helping, but theres no real way to tell how much oil is still getting through.
Old Jul 26, 2012 | 06:28 PM
victorf's Avatar
victorf
Well, I just settled on the principle of "that much less".
There is never a 100% on anything, at least, that's how I see it!
Old Jul 27, 2012 | 01:16 AM
JCtx's Avatar
JCtx
Just emptied the catch can on the '12 dry-sump GS after a trip to Colorado (around 1,300 miles), and it had about 2 ounces. Not a whole lot, but still a crapload of oil otherwise going thru the intake. Not an 'enjoyable' mod, like window tint or aluminum pedals, but glad I did it. Hope GM fixes that crappy PCV valve on the C7 once and for all .
Old Jul 27, 2012 | 11:58 AM
JRHAWK9's Avatar
JRHAWK9
I put one of those glass fuel filters inline of the return hose in order to monitor the effectiveness of the catch can. I used to have the can mounted to the passenger side head. Now it's mounted on the front main support behind the bumper and has mainly copper tubing for an inlet hose. In my experience, what made a big difference for me is moving the can away from the source of heat and adding a copper intake line. These two things drastically helped in cooling the vapor allowing the oil to fall out of suspension more effectively. Before doing these two things I was seeing residual oil in the monitoring filter that was getting through the catch can. I am now seeing nothing in the monitoring filter.
Old Jul 27, 2012 | 12:01 PM
JRHAWK9's Avatar
JRHAWK9
The LS3 doesn't have a PCV "valve" to fix
Old Jul 27, 2012 | 02:10 PM
victorf's Avatar
victorf
Have you touch the front frame member behind the bumper where you'd mounted your catch can after a drive?
I don't know about your car, but on mine unlike the Z with its bumper air vent, temperature seems to feel the same as the side frame rail, fact is, metal do conduct heat, appears it averaged out in an confined area.
It would be interesting to used a non contact temperature gauge to take some readings!
Old Jul 27, 2012 | 04:26 PM
JCtx's Avatar
JCtx
Of course it does. Federal requirement (PCV= positive crankcase ventilation). It's not an electric valve, if that's what you meant. It's supposed to allow oil vapors only, but the crappy GM design obviously could be better. Baffles and steel wool is all that is needed, but how you build it makes a big difference.
To Catch Can Works
Old Jul 30, 2012 | 10:04 AM
JRHAWK9's Avatar
JRHAWK9
No, I have mainly just touched the can itself and that was cooler. I have my shroud cut for my Vararam, so it may be a bit different.
Old Jul 30, 2012 | 10:27 AM
JRHAWK9's Avatar
JRHAWK9
It has a PCV system, but not a valve. -THIS- is a typical PCV valve which is not present on the LS3. My LS1 has one.....don't know if the LS2 does or not.
Old Jul 30, 2012 | 12:47 PM
victorf's Avatar
victorf
Cutting shroud for Vararam has slight gap? Or does it equal to pop the bottom flap?
Certainly getting air there helps! Glad that worked out for you!
