Exhaust removal help pls
Old Jul 26, 2012 | 12:50 PM
nmarple254's Avatar
nmarple254
Default Exhaust removal help pls
I'm trying to take the mufflers off my 05 c6 but I'm not having any luck. I have the clamps loosed at the H and I took the mounts off of the rear frame at the bumper. The issue I'm having is that I can't pull the muffler pipe any farther out of the H pipe because the muffler is hitting the bumper frame support at the back. Do I need to take the H pipe off at the front as well and pull it forward? I've seen install videos of people turning the muffler sideways to install but I cant get mine to turn. Thanks for any help.
Old Jul 26, 2012 | 01:01 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
You got it! Drop the H pipe front connectors and pull.
Old Jul 26, 2012 | 01:17 PM
nmarple254's Avatar
nmarple254
Ok thanks guess ill take the back wheels off the ramps and put up the front. Don't think I can squeeze all the way to the connectors with the backs up.
Old Jul 26, 2012 | 06:51 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Once you've got the front loose, you are going to need to get the rear back up. Once the mufflers are loose from the H-pipe you are going to need to turn / twist / pull to get them out; they will fight you but they will eventually come out.
Old Jul 29, 2012 | 10:33 AM
nmarple254's Avatar
nmarple254
Well I got it all done. The hardest part is just getting the back up, then the front, then the back again. It sounds great to me. A question though is it going to cause and damage now that my exhaust is exiting right into the axle and all of its components now? I don't really want to install turn downs but I will if I have to.
Old Jul 29, 2012 | 12:05 PM
jpee's Avatar
jpee
I would.. it's not expensive, & will prevent the HOT exhaust gas from hitting the rear...
Old Jul 29, 2012 | 01:41 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
So you are running mufflerless now? I thought you were installing some different mufflers.
Old Jul 29, 2012 | 08:25 PM
nmarple254's Avatar
nmarple254
No I just took them off completely
Old Jul 30, 2012 | 09:33 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
For one thing, hot exhaust hitting rear transverse leaf spring will damage it.
Old Jul 30, 2012 | 09:42 PM
nmarple254's Avatar
nmarple254
What size piping do I need the turn downs made out of? Does anyone make instock ones or do I need them custom made?
Old Jul 31, 2012 | 06:40 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
It's 2.5" piping. Go to your local autozone, pep boys, or whatever auto accessory store and you can probably find chrome turn down exhaust tips for a few bucks.
Old Jul 31, 2012 | 09:56 PM
nmarple254's Avatar
nmarple254
Sounds good. Thanks for the help.
Old Aug 22, 2012 | 03:46 PM
nmarple254's Avatar
nmarple254
I'm having a heck of a time finding the right size turn downs. Anyone happen to have a link for a set? The ones I found at autozone were to long.
To Exhaust removal help pls
