oil leaking.
Old Jul 29, 2012 | 02:43 AM
2fastfu's Avatar
2fastfu
Default oil leaking.
I just added a stock oem oil adapter so that i could run a oil to air external cooler like the ls2,ls3,ls7 use that attaches to the oil pan right fitting right above the oil filter. i had to remove a cap there to tie in the new adapter, all of the lines hooked up just fine except that it looks like it's leaking on the left bolt just a little. Is there a better gasket to use ? can i add some kind of sealer or silcone or something similar to that would help the gasket to seal so it doesn't leak any more.
I heard you could bolt the oil adapter to straight metal to adapter and use sealer in between? Any opinions?
Old Jul 29, 2012 | 03:54 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Old Jul 29, 2012 | 07:41 PM
2fastfu's Avatar
2fastfu
Originally Posted by Gearhead Jim
nothing at all?
Old Jul 30, 2012 | 10:16 PM
Gearhead Jim
St. Jude Donor '13
Sorry, I don't have the Z51 oil cooler but have been thinking about adding one.
You might try posting in C6 General, they can discuss stuff like this too.
To oil leaking.
