with medium to full throttle happens right at 2300 rpm to 3000 rpm before the lovely stingers drowns out the sound.
Here's what I've done so far
isolated intake, brake cooling ducts etc, still rattled
replaced rubber shifting bushings just in case, still rattle
took it to the dealer saturday, tech drives it and hears the noise. Hooks up tech 2 and says random misfire cylinder 2. They end up replacing all 16 lifters, and putting in a new camshaft. Also got new valve covers, head gaskets, and exhaust manifold gaskets(this was my next guess). Call me and tell me vehicle is ready yesterday. Get it out today and let it warm up before giving medium throttle again and hearing the exact same noise,
what else can cause this? Noise differs between hard rocking sound to sounding like paper flapping in the wind. Very annoying. Any help is greatly appreciated, thanks
I hope it's not the mufflers rattling against the transmission after they did all that...exhaust hitting often shows up on scans as detonation and my Borlas would rattle unless they were adjusted perfectly.
Look for shiny spots on the mufflers and pipes. If possible, look while on a drive on rack like an alignment rack as you want the weight on the wheels when checking.
Can you duplicate the sound while sitting still, or only while in motion?
(I have more questions than answers...)
I can duplicate the sound in neutral however its greatly diminished. Very noticeable in gear with hard acceleration. If i accelerate smoothly in gear, no noise. Medium to full throttle and flutters/rocking sound appears.
Originally Posted by Toxic c6
what fuel are you running? sounds like detonation.
93 Shell
I am taking back this Saturday and specifically ask that they put it on a lift this time and have one tech under the vehicle while another has the car in gear and accelerates at that rpm range, they stated it wouldn't be a problem.
There is dry brown stuff on the driver side motor mount but I had a Corvette mechanic(Doug Ward) in Knoxville look over the vehicle a few months ago and he stated that the motor mount was ok. That was my first suspicion. Hopefully can get this squared away this Saturday but still wanted opinions from other owners.
I had a similar "rattle". I turned out to be the passenger side rear o2 sensor was 1/2 turn loose. Had a heck of time trying to tighten without taking it apart. Once I tightened it, all the noises went away. At one time I thought it was the cat falling apart inside the pipe.
Hope this helps and good luck,
Noe
Thank you, I will have them check this tomorrow.
Originally Posted by SUB VETTE
My guess is a faulty Cat that is rattling.
I've mentioned that but the techs seem certain that the car would be giving a code if the cat wasn't functioning properly. If they say they can't find anything tomorrow I will have an independent shop remove the cats and inspect them.
food for thought, my tunnel plate was loose and making noise.
Good point. I changed my tunnel plate to the insulated and thicker plate made by Elite Engineering when I installed headers. When I did, I found about a half dozen of the mounting bolts were loose on the original.
This may sound ridiculous, but I had a similar sound about 3 weeks ago. It was driving me mad. The power steering pulley has a push in pin that acts as a dust shield. Its a plastic POS that had walked out 3/4 off the way and was creating the exact sound you are describing above 2000RPM and it was driving me crazy. I pushed it back in and guess what? No more sound. You might check it. Hope that's the problem. Good luck.
Service advisor and tech that I was supposed to see yesterday weren't even there! Who sets an appointment with someone to review the work you did on the car and you aren't even scheduled to work that day! Ridiculous. Heading back Weds to have them put it on the rack.
I will check into the Power steering pulley to see if I can find what you're referring to in the meantime, thanks
I'm sorry to hear you have had this issue. Were you able to reschedule your appointment for today? Please keep me informed on your situation.
Evan, Chevrolet Customer Service
I am supposed to return Wednesday, another service advisor stated he would tell the tech who worked on the car that I would be returning weds evening. I'll keep you posted as this is "currently" the only issue I have with my Vette.
My vette has the same rattle and it comes from the torque tube bearings. I had them replaced twice under warranty and a few thousand miles later the noise returns.
I have been driving it for 2 years with the noise and it is not getting worse so I am only going to have them replaced again if the noise gets worse.
The dealer said it was a 12 hour job last time so I would expect $1,000 plus labor bill.
Douglas in Green Bay
You must have a bent driveshaft or stub yoke. It's not normal for the bushings to go out, particularly if you are not road racing. You might want to get those parts checked for runout next time you get the work done.
Ok thank you. A few questions if I may:
-Do you remember how they diagnosed it? Hopefully by putting it on the rack. The tech drove it last saturday and thought it was coming from the engine without even putting it on a rack to check and see. At least I was in the car riding with him when he heard the noise so they can't say it's not there.
