Clicking start push button
Old Aug 3, 2012 | 02:37 PM
Olddudesrule's Avatar
Olddudesrule
Originally Posted by important
What do you do in the event that youre traveling and wont have access to a tender/charger?
I don't worry about having the Tender if I'm regularly driving the car, but if it's gonna sit for a few days or more at home, I hook it up. If a modern battery is in a good state of charge, it should hold sufficient voltage to last several weeks or more without needing to be hooked up. Our cars, like others such as the Viper, draw small amounts of power when they are off, and are fickle when it comes to the batteries not being fully charged.
Old Aug 4, 2012 | 05:53 PM
kp's Avatar
kp
My '12 has clicked, engine light on and no crank when pushing the button twice since new (both times while stopping somewhere when driving). My '07 and '08 would do that too occasionally. Its probably something with the fob not being right when it goes to start, the fob/pushbutton start on these hasnt really been updated since '05 and they do have their occasional quirks.
As mentioned the 'clicking' noise behind the dash is normal when you go to start it, it bothered me when I bought my first C6 in '06 but I'm used to it by now..
Old Aug 4, 2012 | 06:26 PM
Olddudesrule
I agree with this^, but mine has never clicked. Very rarely, after pushing the start button, the dash will light, the needles will move as normal, but it won't start. I wait a sec, push it again, and it always starts the second time. I agree it's probably just a small, temporary electronic glitch, possibly related to the fob's location. Never had it click though....
Old Aug 4, 2012 | 07:27 PM
kp's Avatar
kp
Mine does the usual clicking then stops, no gauge sweep or anything else lit up, just the yellow engine shaped light on. If I press to start again its dead, have to shut it off and it has always started on the next try.
The other times it happened on my other C6s it may or may have not clicked and done what you have described, I just dont remember
I'm used to the fob weirdness though so I dont pay much attention, 50% of the time the hatch wont open from the back if I walk up to it locked, 10% of the time the door wont open when locked the first time, warning for the fob in the car when I'm walking away with the fob in my pocket etc, all my C6s had did the same things. I daily drive them so I start stop at least 3 times a day..
Old Aug 4, 2012 | 09:38 PM
Scooter275's Avatar
Scooter275
I have done this and had it go completely dead to the point where I manually opened the doors to get out (no electricity). Then gone back to the trunk and was able to open it with the regular switch! Got back in and it started up! Makes me think it wasn't sensing the key fob.
Old Aug 5, 2012 | 09:03 AM
kmthor00's Avatar
kmthor00
Originally Posted by luvchevs
Anyone have this on their C6?
Solution?
Dave
Normal, did it on my 2006, 2007 & my new 2012 GS
Old Aug 6, 2012 | 12:00 AM
Scooter275's Avatar
Scooter275
My car had the battery replaced just before I bought it. further inspection revealed very loose battery cables seems to be better
Old Aug 16, 2012 | 03:44 PM
markab's Avatar
markab
ahh now i know what my issues are, i will have my battery checked out, by the way where can i get a abttery tender
Old Aug 16, 2012 | 05:53 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Got mine on Amazon, but they are pretty widely available from many vendors.
Old Aug 16, 2012 | 11:02 PM
Keith Tedford's Avatar
Keith Tedford
As Pete pointed out, the computer systems can be fickle if the voltage isn't right where it should be. I was talking to a car friend who worked in GM and worked on cars that stumped the dealers' mechanics. He cringes at the thought of even owning one of these cars. He's seen too many problems. He also stated that good connections at the battery or anywhere in the car including grounds have to be perfect or you start to get warning messages. The old cars were relatively simple to diagnose. This stuff can be a nightmare.
Old Aug 18, 2012 | 11:04 AM
MP35N's Avatar
MP35N
Default Starter Terminals
If clicks and/or drains voltage rather than starting it is likely to be the Starter. The solenoid terminals are close to the exhaust and they/it goes bad.
Old Dec 12, 2012 | 11:22 AM
Greg00Coupe's Avatar
Greg00Coupe
I'd describe the noise on my new GS as an electrical arching. Does not sound right to me. I have a Cadi with button start and it does not make any arching noise. Plus on two occasions I hit the button and got nothing. Hit the off side, and hit on and it started up. I'm thinking I have an electrical issue brewing.
Old Dec 12, 2012 | 01:25 PM
  #33
KenVette57's Avatar
KenVette57
I had the same issue. I went to my mechanic and it turned out to be a loose Negative cable clamp on the battery. I was experiencing a slow start, almost like a low battery, and after the Negative was tightened the puppy starts right up. Just something to think about.
Good Luck
Old Dec 12, 2012 | 02:16 PM
  #34
anniv88's Avatar
anniv88
I'm talking about a quiet clicking noise that sounds like it is coming from the push button when you press it or when you step on the brake.
Dave
My 2011 GS does the same thing. The dealer said it's normal. We
checked 2 new cars on the lot and they did the same thing.
Old Dec 12, 2012 | 07:16 PM
  #35
JCtx's Avatar
JCtx
My '12 dry-sump GS (battery in hatch) has done it a couple of times too, and with battery fully charged. It's a cacophony of relay noises behind the ignition button. A third time it did the same thing... BUT I pressed the lower part of the button, rather than the top . At least the first time I'm positive I pressed the green (upper) button. Another possible issue for us manual owners is not depressing the clutch pedal all the way in. And the third, and probably what happened to me at least the first time is interference. There were a bunch of overhead power lines in that area. But the second time it fired up right away. Hasn't happened in a few months, so definitely normal. All modern cars, with all their electronic crap, will have 'idiosyncrasies' like that, unfortunately. My ex M3 didn't recognize the damn fob 8 out of 10 times. THAT was really annoying. This I can definitely live with. No sense in even mentioning to a dealer if it's sporadic and not repeatable. Good luck.
Old Dec 14, 2012 | 11:41 AM
  #36
Larry/car's Avatar
Larry/car
Good reason to not keep these computer operated cars to long. Wire/connector corrosion will be a nightmare in the future. Mileage/usage actually will not accelerate this terminal corrosion, may even slow the process.
Old Dec 15, 2018 | 09:15 AM
  #37
Adrian James's Avatar
Adrian James
1st Gear
Default 2010 c6 wont start just click when button is pushed
Originally Posted by rokn91rs
Sounds like a dead battery or a loose connection on the battery.
Just replaced the alternator battery readings 12.6 just a click when start can anyone help or advice
To Clicking start push button
Old Dec 15, 2018 | 11:48 AM
  #38
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
I keep hearing some folks say that they checked there battery voltage and it was 12 volts or more, but, for some reason it still won't start the car.
Well, battery voltage is only one piece of the puzzle ... The other is cranking amps ... Sure, you can have 12+ volts, but if the battery has little to no cranking amps, the car won't start.
That clicking noise you hear is just the starter's solenoid trying to engage the starter .... If you have a battery with no cranking amps left, then that clicking sound is all your going to get when pressing the start button.
Buy a new battery !
Old Dec 15, 2018 | 03:16 PM
  #39
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
And start a new thread. This one was brought back from 2012.
Old Dec 17, 2018 | 03:28 PM
  #40
erikszr1's Avatar
erikszr1
whats scary is guys messing with dead batteries and jumper cables on these cars............electrical system hates them. guys need stop playing with dead batteries and just replace them. BCM's ECU's, starters, and connections all get stressed out w low voltages. all that clicking your hearing is stuff trying to work without proper battery voltage. Use jumper cables only if your life depends on it, in most cases it wont. i left the big words out. simple
