Ls2 maf to ls3/ls7
Old Aug 14, 2012 | 12:47 PM
UmX's Avatar
UmX
Default Ls2 maf to ls3/ls7
Thinking about grabbing one of these
http://www.ebay.com/itm/LS3-LS7-MAF-...-/250994672725
Unless someone else on here has a vendor that sells them cheaper.
Also need to buy some 4 inch black silicon to cut out for the intake anyone know a good place.. Also requires tune adjust correct?
nvm found this site
http://www.siliconeintakes.com/index...52a6de695679b7
Old Aug 14, 2012 | 12:59 PM
C7&7's Avatar
C7&7
This is where I bought mine when I did the LS7 intake / maf conversation. Worked great.
Old Aug 14, 2012 | 01:03 PM
UmX's Avatar
UmX
forgot the link i think haha.. thanks!
Old Aug 14, 2012 | 01:05 PM
C7&7's Avatar
C7&7
No I meant the ebay link you listed above is the place I bought mine. The one you posted!
Old Aug 14, 2012 | 01:07 PM
UmX's Avatar
UmX
Ahh k. thank you.. Trying to find a threads with benefits of having a ls7 over ls2
Old Aug 14, 2012 | 01:10 PM
C7&7's Avatar
C7&7
Well the reason I did it was do go to the larger intake inlet on the K&N FIPK. I picked up 11 to the tire with just the intake swap and LS7 maf.
Its worth it if you're switching intakes also. You wont see much from just a maf change.
I went from this intake, LS2 style:
to this intake, notice the larger outlet on the filter and covers the filter outlet basically all the way across:
LS7 Style
Old Aug 14, 2012 | 01:14 PM
UmX's Avatar
UmX
I got a vararam for a ls3 i modified to fit my ls2, but i have a alum cut for the ls7 maf and what not I would like to get it put in and correctly. Ill need some silicon ext to make it work but ya
Old Aug 14, 2012 | 02:17 PM
EVL JAKE's Avatar
EVL JAKE
St. Jude Donor '12-'13
I run an LS3 MAF with my 103 Halltech. Works good so far.
Old Aug 14, 2012 | 06:30 PM
RussM05's Avatar
RussM05
I gained 17 rwhp when I switched over from the stock MAF on my LS2 to a LS3/LS card style MAF and the 90mm Halltech air bridge. The Halltech filter would not fit, so I had to use the K&N.
Old Aug 14, 2012 | 09:44 PM
journeyc6's Avatar
journeyc6
so what do I need to do this transformation?: harnes, LS3 MAF.....
Old Aug 15, 2012 | 04:43 AM
taken19's Avatar
taken19
Track Junky
You need the sensor itself, a housing for it ( CAI), wiring harness adapter and tune. The newer MAF has a much broader range, 12.5 kHz vs. 5 kHz. With no tune, the ECU thinks the motor is getting about half the air it's actually pulling in and will cut fuel accordingly. Car will run like crap or not at all. Tune is a must before driving it...
Old Jun 26, 2016 | 01:46 AM
orripid's Avatar
orripid
LS7 Style
I know this is a old thread but i am doing this now. Can you just use the stock z06 maf tables to get this running ok?
Old Jun 26, 2016 | 10:14 AM
C7&7's Avatar
C7&7
I am sure that is exactly what you do in the tune.
To Ls2 maf to ls3/ls7
