Blowers and ride height
Old Aug 29, 2012 | 09:07 AM
godzilladude's Avatar
godzilladude
Default Blowers and ride height
So, let me try this another way.
Do those with blowers typically have the nose sit lower from the weight of the equipment? And if they do, is it something that they just raise it back up, if they want, via the height adjustment bolts?
My problem is, added the blower, and the nose was sitting on the ground. Literally dragging down the street. I raised the bolts as high as they would go, and now the spoiler is maybe an inch off the ground.
I had had the front spring replaced not too long before that, because the height bolts had gotten frozen. The replacement had been a used unit that the shop had at hand, not a new one, no idea how many miles. Now I'm wondering if the problem is the spring they installed was really just old and shot, and I need a new one.
Old Aug 29, 2012 | 10:02 AM
j_digi454's Avatar
j_digi454
Originally Posted by godzilladude
SDo those with blowers typically have the nose sit lower from the weight of the equipment? And if they do, is it something that they just raise it back up, if they want, via the height adjustment bolts?
My E-Force dropped the front 3/4" which I corrected by turning the height adjusting bolts 4 turns. The ride height is now where it was before the install (I measured it before the install). I believe the E-Force adds a net 75 lbs. I don't know about the others.
Old Aug 29, 2012 | 10:42 AM
madmax4499's Avatar
madmax4499
wow i think i could sit on the engine and not have it go that low, i think something is wrong. i did three full turns on mine to help with the weight of the TTiX. do you have stock size front tires?
Old Aug 29, 2012 | 12:32 PM
FloydSummerOf68's Avatar
FloydSummerOf68
After my A&A install the airdam will occasionally drag on the street if there are some inconsistencies in the pavement. It sits about 1/2" off the ground.
I like it that low though. As long as the car isn't scraping I don't care. Looks great
Old Aug 29, 2012 | 12:48 PM
JoesC5's Avatar
JoesC5
A friend that has a Maggie installed on his GS, sits 3/4" lower at the nose, then my Z06. Sounds like the used spring you had installed is bad.
Old Aug 29, 2012 | 01:19 PM
j_digi454's Avatar
j_digi454
I like it that low though. As long as the car isn't scraping I don't care. Looks great...
Some Forum members have dropped the rear to match the front drop instead of raising the front. I thought about it but I drag my front air dam just getting out of my street and decided to just raise the front.
Old Aug 29, 2012 | 11:24 PM
corvette dave's Avatar
corvette dave
No, I drove the nuts as far as they would go, and that moved it up significantly from where it was, but it was on the freakin' ground. I can drive it now, but there is not much room.
But a good first guess, I suppose.
It was a good first guess since if turning the bolts the right direction didn't get the height back to normal then you have another problem.
A damaged spring would be another good guess, I suppose.
Old Aug 30, 2012 | 01:18 AM
stivette's Avatar
stivette
Where in north Texas are you? I'm in Carrollton, I can take a look at this weekend. I've pulled my suspension apart replacing lowering bolts twice and once for a camber kit so I'm pretty familiar with the way everything should look and be adjusted. Shoot me a pm
Old Aug 30, 2012 | 09:13 AM
godzilladude
Yep, stock sized fronts.
Old Aug 30, 2012 | 09:15 AM
godzilladude
Well, and in general, I like the look and ride as well. I just wish it was a skoshe higher, and the bolts being driven completely as far as they can go already, make me wonder if I need to replace something else.
Old Aug 30, 2012 | 09:30 AM
ZRCLONE's Avatar
ZRCLONE
Actually if you do drop the rear, it will raise the front a little. Just another option if you can deal with the car being low. Where I live, mine is as low as I dare and still have to be careful.
Old Aug 30, 2012 | 09:02 PM
godzilladude
Hadn't thought about that. The rear is already lowered a bit, but I might move it a bit more. Thanks!
To Blowers and ride height
