Cam question: converting LS3 to 3-bolt, can I reuse my LS3 chain and tensioner?
If I want to run a 3-bolt cam/sprocket setup, can I just buy the 3-bolt sproket and reuse my 13k mile LS3 tensioner and LS3 chain?
Someone told me that if you have 3 bolts, all of them have to back out to cause major problems (which you'd hopefully hear). If you only have 1 bolt and it backs out, it's too late to do anything. I can actually order my cam either way, 1 bolt or 3 bolt.
It seems the LS2/LS3 timing chains are strong enough to re-use. So no need for a C5R chain?
sounds good for more safety.
False security ....
Former Vendor
I use the C5R Timing Chain and the LS2 Timing Chain Damper. The LS3 version is very thin and I have seen them break. It is to complicated of a design and the LS7/LS2/LS9 uses a solid damper and works like a champ. They are cheap too.
St. Jude Donor '11-'12-'13-'14
LS9 pictures I've seen show it using the tensioner, not the dampener. Did they change at some point during the ZR1 production?
Cruise-In VII Veteran
just saw your chain note, it's 50 for a new LS2/3/7/9 chain or 150 for a new IWIS C5R chain, it's free labor when replacing a chain on a cam swap..........I would.
sorry to revive an old thread, but information on this seems to be plentiful but incomplete, and this seems to be the most concise info I've found.
So... LS3 head/cam swap to a 3 bolt.... I should go with something like the lingenfelter 3 bolt steel sproket, c5r chain (any REAL difference between hinson and katech here?), and the simplified design of the ls2 style dampener? How many folks change the sproket and dampener and keep the oem chain? In my reading, it actually seems like the chain is not as likely to be the problem as people make it out to be.
https://www.summitracing.com/parts/l...RoCS7wQAvD_BwE
4th Gear
