Check engine light
Old Sep 10, 2012 | 01:43 AM
harrydirty's Avatar
harrydirty
Default Check engine light
Last trackday in my '07Z noticed the car would buck when I let off the gas abruptly. I thought that perhaps I had overheated the clutch due to my newly-found heel and toe downshifting skills.
I was at the track again today and noticed the bucking was still there, although it happened only a few times. However, during the second session the engine check light came on. Since the car seemed to be running ok, I decided to keep going and finished the session. When I started the car for the third session the car's idle was erratic, going from 900-500 rpm and when I took it onto the pit lane, it would buck and almost stall out when I hit the gas pedal hard; it was running erratically. Then in about a minute, it all cleared and ran normally. After that, every time I started the engine it would idle and run erratically, then clear after a couple of minutes and run fine, with the idle steady at 650 rpm and running normally in all gears. Engine check light is on steady.
I did a search on the forum but not much applied directly to my issue......I would appreciate any help from the combined wisdom of the forum. Thanks.
Old Sep 10, 2012 | 10:13 AM
mattdracing's Avatar
mattdracing
hmmm...thats interesting. do you have any mods done to your car or is it bone stock?
Old Sep 10, 2012 | 10:25 AM
jjas's Avatar
jjas
Had same problem this weekend. Interested in responses. I,ve many mods, never had check engine light come on before.
Old Sep 10, 2012 | 10:28 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
If the light is on and you don't have a reader, any auto shop (autozone/oreilly/advance) can read and print the code for you for free. That would be the best place to start I think.
Old Sep 10, 2012 | 11:47 AM
harrydirty's Avatar
harrydirty
No mods to drivetrain/engine........I'll see if the local O'Reilly's will read my codes, thanks for the suggestion.
Old Sep 13, 2012 | 02:30 AM
harrydirty's Avatar
harrydirty
Had a buddy read the code and reset check engine light......code was P0101 which indicates a MAF issue. Should I just clean it? Anyone experience this issue with their C6Z?
To Check engine light
