de-stroke 454
Old Sep 15, 2012 | 03:33 PM
Z06SlapMopar's Avatar
Z06SlapMopar
Default de-stroke 454
i was wondering if it would be possible to de-stroke my lsx 454 and rev it too 8,000 rpms?
Can any experts or non experts shed light on this.
ThankYou, Z06 SlapMopar.
Old Sep 15, 2012 | 03:50 PM
timd38's Avatar
timd38
Ask for Carl.
http://www.wegnerautomotive.com/
Old Sep 15, 2012 | 04:28 PM
pit-man's Avatar
pit-man
Robz had his 427 destroked to a 388. He found he had computer problems with going over 8k. He ended up short shifting around 7900 and still ran somewhere near a 9.4 ET....NA
Old Sep 15, 2012 | 04:32 PM
pit-man's Avatar
pit-man
Here is a vid I found
http://www.youtube.com/watch?v=nY-ZW...layer_embedded
Old Sep 15, 2012 | 05:54 PM
LSOHOLIC's Avatar
LSOHOLIC
Was there a specific reason for wanting rpms ?? Because unless the "entire" car is built for it....it will ultimately be slower. 9 times out of 10...cubes are the answer....especially in a N/A environment.
Old Sep 15, 2012 | 07:08 PM
Z06SlapMopar
Not really, my stock lsx 454 Dyno'd 544rwt and 524rwhp. I will try too post the dyno sheet, it has a huge torque curve. and reaches the 524hp @5700rpm.
i want too shorten my 1/4 mile times. And be a highway monster.
what should i do?
i destroyed a lamborgini on the highway today
not sure how hard that its too do.
Old Sep 15, 2012 | 07:45 PM
LSOHOLIC's Avatar
LSOHOLIC
Not really, my stock lsx 454 Dyno'd 544rwt and 524rwhp. I will try too post the dyno sheet, it has a huge torque curve. and reaches the 524hp @5600rpm.
what should i do?
Ummmm...it seems you contradicted yourself unless I'm mis-understanding what your saying (which is completely possible).
So you love the tq curve but what less cubes and spin it higher ??
just some questions for ya....
~whats the most rpm that you have seen the Fast style manifold support (esp at your cube.) ??
~what are your thoughts on valvetrain stability and have you priced these items ?
~have you researched the factory ecu and its limitations ??
~do you have an idea about the camshaft that will work in this senario ??
~will your current heads support the cfm required for this ??
~etc..etc....
IMO, there is a reason the GM produced the LSX 454....it is a perfect "street" setup. Killer power down low and 100% streetably with "low" buck parts.
It sounds like you may need to sort out the rest of the car (to keep you in the power through out the pull).
Could you explain what you think the "high" rpm will achieve ??
Or is it wanting more upper hp ??
Also, are you auto or manual ??
Thanks....
Old Sep 15, 2012 | 08:23 PM
Z06SlapMopar
I cant thankyou enough for taking your time and helping me with this.
(the de-strokeing was mostly curiosity)
Yes, i am looking for more high rpm horsepower.
i think the first step is for me too up grade to the ported fast 102.
now here is where i need some help, so correct me if i'm wrong.
i want faster 1/4 mile times, so the obvious change would be the rear gearing. lets say 3.90's, would this kill my highway action?
Next is caming. if i put in a after market cam it will give me more horse power and less torque. where is this beneficial?
or should i skip the little stuff and throw 5lbs of boost at it?
Thankyou again
Old Sep 15, 2012 | 08:29 PM
Z06SlapMopar
i forgot, its a Manual w/ ls9 clutch.
Old Sep 15, 2012 | 08:45 PM
LSOHOLIC's Avatar
LSOHOLIC
what does your car weigh ?? Where does it fall off (RPM) ?? What do you shift at ?? What rpm does it make max hp and tq ??
Thanks...............although you have no said this....sounds like you want more topend pull ?? with your driving style, is the 500+tq useable ??
Old Sep 15, 2012 | 09:50 PM
Z06SlapMopar
WEIGHT
i have a 08 base c6 coupe. i think it weighs 3200lbs but i think the lsx is 150lbs heavier so 3350lbs.
RPM
i ONLY dyno'd my car too 6,100rpm
Max HP 524 @ 5,700
Max TQ 544 @ 4,500
from 5,700 - 6,100 horsepower is on a slight down slant, only enough too drop HP to 519 @ 6,100.
After 6100 i'm not sure, i assume it falls off harder somewhere soon.
SHIFT
i,m shifting at 6,500rpm.
my rev limiter is set at 7,000.
IS 500TQ USEABLE
I'm not sure what you mean by this but i have 2 general ideas.
1st idea is that i'm not afraid to Downshift, instead of letting the RPMs build?
2nd idea is that your asking me "if i don't have a need for towing capacity or to get a very Heavy vehicle moving, then do i even need 500+TQ?"
MORE INFO
Right now the car spins first gear.(unless i roll the throttle like a gentelman)
second gear only spins towards the top.
Third through Sixth is smooth sailing.
Thank you again, SlapMopar.
Old Sep 16, 2012 | 02:13 AM
LSOHOLIC's Avatar
LSOHOLIC
[QUOTE=Z06SlapMopar;1581839021]WEIGHT
Old Sep 16, 2012 | 02:49 AM
HC Mechanic's Avatar
HC Mechanic
Shorter stroke, in this case anyway, generally means better horsepower and better acceleration. Just keep in mind, the monster midrange you have now would diminish.
Just make sure if you decide to go the short stroke route, you have everything to support the higher revs:
Higher flowing heads, bigger cam, proper intake manifold, and strong/lightweight valvetrain. And of course, rods and pistons made for the piston speed your looking to run.
Old Sep 16, 2012 | 07:51 AM
timd38's Avatar
timd38
Sound like a lot of money and work for less performance.
But if that is what you want, why not sell the 454 and buy a new engine?
Old Sep 16, 2012 | 09:12 PM
Random84's Avatar
Random84
I'd look at opening up the intake first, gears second, and weight reduction (of the car) If that's not enough - sell it and start from scratch, which is basically what you're trying to do.
Old Sep 16, 2012 | 10:00 PM
LSOHOLIC's Avatar
LSOHOLIC
Hey Mr ZO6slapmopar......how well does your tq curve hang on past peak tq ?? Is it a table top or does it fall off quickly after peak tq ??
When you shift at 6500rpm....does it feel like it noses over...or is it still pulling ??
If your still interested in more rpm.....there are a few thing to look into that would help you now and later if you decide to spin it harder. So...as you know some of the first things would be more air and rpm stability. Aka; valvesprings, valves (lighter), lightened rockers, rigid pushrods, better breathing manifold & TB. Now you many already have some of this stuff or know the specifics about your combo. But either way, these items will net a return on your current setup and a future raise of the rpm. The two biggest things that would effect you moving the rpm up a little would be camshaft and manifold.
Thanks.....just fyi, the flater and higher you make peak tq the faster your car will be. The most combustions down the track wins !!....LOL
Old Sep 17, 2012 | 08:42 AM
robz's Avatar
robz
Aside from all the theoretical.....
If you have a dream, you can make it happen.
Old Sep 17, 2012 | 08:56 AM
timd38's Avatar
timd38
I bet that you could get a person on the forum to swap you their LS3 for your 454.
To de-stroke 454
