Manual vs. Auto Diff
Old Sep 15, 2012 | 06:29 PM
timd38's Avatar
timd38
Default Manual vs. Auto Diff
I want to build a new diff for my car. I know I don't want 05 diff, but I find several newer diffs from auto trans cars. Is the gear ratio the only difference?
The plan is 3.73 gears, so the stack gears don't matter. Basically need it as a core.
Thanks!
Old Sep 15, 2012 | 07:06 PM
haljensen's Avatar
haljensen
It may have changed but the '05 auto 2.73 diff case was smaller than the manual case. 3.42 gears from the manual were too large to fit the 2.73 automatic case.
Some companies were making ring and pinion sets in other ratios for either case and for later model C6's though.
Old Sep 15, 2012 | 07:12 PM
timd38's Avatar
timd38
Thanks! 05 diffs are different, but I was hoping that the 06 and newer used the same case for a manual or auto.
Old Sep 15, 2012 | 07:59 PM
haljensen's Avatar
haljensen
Ratio depends on tooth count of ring gear and pinion gear, More teeth requires a larger ring and pinion to keep the same minimum tooth size.
The higher ratio of 3.73 requires more teeth than a 2.56/2,73, more teeth rquires a larger ring and pinion.
Logic would lead me to think a higher numeric ratio would require a larger ring and pinion. Larger ring and pinion means a larger diff case? Maybe why the 9" Ford is popular and stronger than the 8.8" Ford?
Old Sep 15, 2012 | 11:14 PM
irok's Avatar
irok
You can use the 06 manual differential in your 05 auto. 06 manual diff comes with 3.42 gear and 3.73 gear will work with it. dont think auto 06 diff will work with 3.73 gear but may be mistaken on that. need diff that works with 27 spline output shaft of your 05 auto.first couple years of A6 diff's compatible with 27 spline A4's. possibly the 3.15 geared auto 06 diff may be able to run the 3.73 gear
Old Sep 16, 2012 | 07:45 AM
timd38's Avatar
timd38
Originally Posted by irok
You can use the 06 manual differential in your 05 auto. 06 manual diff comes with 3.42 gear and 3.73 gear will work with it. dont think auto 06 diff will work with 3.73 gear but may be mistaken on that. need diff that works with 27 spline output shaft of your 05 auto.first couple years of A6 compatible with 27 spline A4's. possibly the 3.15 geared auto 06 diff may be able to run the 3.73 gear
Thanks! I have an 06 manual and want to use as 06 auto diff that I can rebuild with HD parts and 3:73 gears. Sounds like I need to get a manual diff.
Now I know why auto diffs are so much cheaper.
Old Sep 16, 2012 | 10:17 AM
haljensen's Avatar
haljensen
No such animal as an '06 A6 3.15 diff. A6 '06 and up is either 2.56 or 2.73.
Old Sep 16, 2012 | 12:43 PM
LS1LT1's Avatar
LS1LT1
If ya can, try and go with the newest/latest model year rear that you can find as there were some minor updates/upgrades (added ribbing, thicker areas etc.) even from the 'already improved' 2006 version to the present.
2006 and 2007 automatic rears were 2.56 only and 2008 and up automatic rears came in both 2.56 and 2.73 depending on model/options.
During the C6 era, only the 2005 automatics (with their weaker rear) had an available/optional 3.15 ratio.
Old Sep 16, 2012 | 12:52 PM
irok's Avatar
irok
new 06 manual diff with 3.42 gear is available from GM for under $1,300.
Old Sep 16, 2012 | 06:48 PM
timd38's Avatar
timd38
So I should be able to by the case and ends for less than that. I want to use the new Eaton carrier with the extra bearing and hardened output shafts.
Thanks!
UPDATE GMPARTSHOUSE wants almost $3K for diff based on what their website says.
Old Sep 16, 2012 | 09:20 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
You must have just looked at the carrier, the new diff is much more expensive than that.
The automatic 06 will actually work but it will need some small machine work done on it. If you can get it cheap, then get one. The gear is not a big deal, while it will have a 2 series carrier, you can get a thick ring gear which will solve that. The only issue is the housing for the manual and automatic is the same, but the VSS on the auto is not final machined. The speed is picked up in the tranny on an automatic car. We machine them all the time, I seem to end up with automatic cores all the time, so we fly cut and drill the casting. The vss boss is already in the case, the casting is the same between auto and standard. A machine shop should be able to do this for easily. Like I said, if you can find it cheap then get it.
Old Sep 17, 2012 | 11:30 AM
irok's Avatar
irok
If your lucky sometimes it pays to shop around. I bought a new 08 ZO6 3.42 diff for $1,450. that we installed in an 09 A6 Z51 car. guess I should have bought all he had. I see the 2nd design manual case and covers available for $ 671. without axle cooling. the Z06 diff I bought does retail for $3,300. at dealer
Old Sep 17, 2012 | 01:43 PM
Zip Corvettes
That would be for the center housing only. The sides are almost 300 ea.
Old Sep 17, 2012 | 01:55 PM
LS1LT1's Avatar
LS1LT1
True, or at least one of the sides are...I believe that one of them is more costly than the other depending on which rear it is?
Old Sep 17, 2012 | 02:39 PM
irok's Avatar
irok
my cost for front cover $27.,left cover with bushing $137.,right cover $114.,housing $390.
Old Sep 17, 2012 | 02:56 PM
Zip Corvettes
I just checked the price, they have come down a little, but you are still not getting a new diff any where in the neighborhood of $1300.
Old Sep 17, 2012 | 03:41 PM
irok's Avatar
irok
would $1,450. for a NIB 08 Z06 3.42 diff be considered in the neighborhood?
Old Sep 17, 2012 | 07:19 PM
timd38's Avatar
timd38
If the Canadian dollar gets really strong, like twice what it is today, I think you buy one for $1,450 Canadian.
Old Sep 17, 2012 | 10:06 PM
LS1LT1's Avatar
LS1LT1
That's not just in the neighborhood, that right inside the garage!
That's an AWESOME price for a brand new C6 Z06 rear, that's even a decent price for a clean (not broken) used one.
To Manual vs. Auto Diff
