Head/Cam Install Questions
Sep 17, 2012 | 12:37 PM
Hey Guys,
So finally getting my head/ cam install underway and here is the setup i have gone with:
2005 corvette LS2
LS3 heads (823) milled .020 (@65.5 cc)
Stock head gaskets
SpinMonster 230/234 .613 .598 114+2LSA
ls7 lifters (converted it to solid to measure the length)
I went ahead and measured the pushrod length with NO preload and it came out to be 7.300... does that sound right?
Also, what is the recommended preload amount; i was thing ~.030; so ultimately i would end up with 7.330 pushrod length??
Thanks in advance!!
Sep 17, 2012 | 12:42 PM
I assume with the LS3 heads your getting and LS3/7 intake manifold of some sort to match the heads intake ports? Just checking.
Sep 17, 2012 | 12:53 PM
Absolutely! using a ls3 intake.
Sep 17, 2012 | 02:00 PM
.040 to .080" preload on LS7 lifters.
