Trunion Upgrade
Old Sep 25, 2012 | 11:57 PM
Danspeed1's Avatar
Danspeed1
Default Trunion Upgrade
I am doing an engine build. I have a lot invested. I just recently started looking into these. Think they might be a nice safety net instead of using stock rockers. I need a set that aren't going to change the Pushrod geometry as I just ordered new pushrods and don't intend on measuring them again. Looking for a quality set; easy home installation. If I can fit it in the budget and its a worthwhile part I will do it. Which ones are the favorite on here?
DG
Old Sep 26, 2012 | 04:20 AM
taken19's Avatar
taken19
Track Junky
Most everyone I have seen (including myself) are using the Come Camp trunion upgrade. The stock needle bearings aren't captured well and are pretty sloppy. Comp Cams are a nice and easy replacement, took me about an hour once off the car with basic tools. Good peace of mind for the money IMO.
Old Sep 26, 2012 | 11:44 AM
turbotuner20v's Avatar
turbotuner20v
Did all of yours rotate freely after install? I found an older thread that mentioned a few per set would bind up.
Old Sep 26, 2012 | 11:57 AM
taken19's Avatar
taken19
Track Junky
A couple were more snug than others. I tapped the trunion side to side a hit and rotated it by hand until it loosened up - they all did. Just need to pay attention on how hard the bearings are pressed in and where the snap ring is in relation to other components. Not difficult, just use common sense.
Old Sep 26, 2012 | 12:20 PM
07MontRedcp's Avatar
07MontRedcp
Were there any spacers/depth gauge included in the kit to control how deep they were set? Seems to me that I ran across that being a possible problem on the LS1 forum.
BJK
Old Sep 26, 2012 | 12:23 PM
taken19's Avatar
taken19
Track Junky
Originally Posted by 07MontRedcp
Were there any spacers/depth gauge included in the kit to control how deep they were set? Seems to me that I ran across that being a possible problem.
BJK
Not in either one that I did. If you have ever done machining or assembly, it takes a certain feel. Just don't go crazy pressing in the bearings. You can feel and see when they bottom out, the goal is to be consistent.
Old Sep 26, 2012 | 12:49 PM
07MontRedcp
And one other question. Do these trunions change the contact pattern on the rocker tip?
BJK
Old Sep 26, 2012 | 12:52 PM
taken19's Avatar
taken19
Track Junky
Should have no impact. You're not changing geometry with cam profile, pushrod length, or rocker arm length.
Old Sep 26, 2012 | 01:06 PM
ZRCLONE's Avatar
ZRCLONE
BJK
They probably will, but you would have to re-check after awhile. I did mine at about 4k and the stock rockers were not scuffed too bad. I really wanted a "full" roller rocker, but was not that impressed with what is affordable. If I would do them it would be the Jessel set up. I did my Comp Cams trunions in the lathe as you do not need much of a press and pressing the bearings in as straight as possible is "very important". The kit I got comes with hardened flat washers to seat the bearings and the snap rings are only a safety measure as they are no where near anything. If anyone is interested in how to do it in the lathe, I would be more than happy to explain. If I used a vice or a press, I would use a good machinist vice with ground jaws that track very flat. Or an Arbor Press so you have some "feel".
The GM "stock" trunions are a real P.O.S. and have a lot to be desired!
Old Sep 26, 2012 | 01:11 PM
07MontRedcp
BJK
Old Sep 26, 2012 | 01:24 PM
Danspeed1's Avatar
Danspeed1
Well I think that pretty much answers all my questions without me actually having to ask any of them. Thanks 07MontRedcp!
I will order them up and we will add it to the build thread!
DG
To Trunion Upgrade
