Ruined my MAF!
Old Oct 3, 2012 | 10:30 AM
fastdoc71's Avatar
fastdoc71
Default Ruined my MAF!
In a quest to try to improve my gas mileage, I had the bright idea of cleaning my 08 LS3 MAF. So I unhooked the battery, carefully removed the MAF, gave 2 quick sprays with CRC MAF cleaner, let it dry for 15 minutes, put the MAF back in, reconnected the battery, and started the car.
It fired up quickly, but then promptly started to sound like a Model T, sputtering until it finally found a somewhat decent idle. I let it run for about 10 minutes, shut it off, started it up again, and got an immediate CEL. Code showed P0102 (MAF low input).
I disconnected the battery again, waited about an hour, fired it up again, and it seemed to start and idle well, and let it idle for 15 minutes. Then turned it off and on again, and the CEL popped back on.
I'm kicking myself because although I run an oiled K&N filter, the MAF didn't even look dirty in the first place. I now have a new one on the way.
When I reinstall it, do I need to have it done by the dealer so they can use a scantool to get rid of the code, or can I just disconnect the battery for 15 minutes, reinstall the MAF and reconnect the battery to clear the code?
Old Oct 3, 2012 | 12:53 PM
dennis50nj's Avatar
dennis50nj
Try clearing the code before buying a new maf
Old Oct 3, 2012 | 02:02 PM
fastdoc71's Avatar
fastdoc71
Already tried, both with OBD reader and disconnecting battery, no dice.
Old Oct 3, 2012 | 03:05 PM
DSOMC6's Avatar
DSOMC6
Did you touch/wipe the critical areas of the maf (not good) or just spray it with cleaner? If you just sprayed it then I would look for a leak or problem at the connection/wiring before I purchased another.
Old Oct 3, 2012 | 03:09 PM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
I've cleaned my maf a few times with maf cleaner and had 0 issues. Are you sure it's plugged in all the way?
Old Oct 3, 2012 | 03:34 PM
RamAir972003's Avatar
RamAir972003
Let it dry look for moisture in wires if you didnt touch anything and just sprayed it like they said you should be fine try blow drying it at a distance to get any moisture out.
Old Oct 3, 2012 | 03:55 PM
Biggie G's Avatar
Biggie G
I just cleaned mine a week ago. sprayed the hell out of it in all directions. then wiped the walls down. i didnt wipe anything but the walls. i let it sit for 10 minutes then installed it.
no issues.
I would get one from a junk yard or car-parts.com before i get a new one
Old Oct 3, 2012 | 04:21 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Try getting it nice and hot with a hair dryer and see if that fixes it. May have gotten some cleaner in a critical area,
BC
Old Oct 3, 2012 | 06:55 PM
fastdoc71's Avatar
fastdoc71
How about I re-installed the MAF upside down? I put it back in the right way and the issue is resolved. Just goes to show you shouldn't work on your car when sleep deprived.
I am an idiot.
Old Oct 3, 2012 | 06:57 PM
el es tu's Avatar
el es tu
Everyone eventually deals with that kind of crap. Im sure youre glad to just be done with it though.
Old Oct 4, 2012 | 08:54 AM
jss06c6's Avatar
jss06c6
I've got an extra MAF out of my '06 with only 25,000 miles on it. PM me if your interested in it.
Old Oct 4, 2012 | 12:14 PM
fastdoc71's Avatar
fastdoc71
Thanks for the offer, but I got everything working again.
Old Oct 4, 2012 | 12:29 PM
jss06c6's Avatar
jss06c6
Great!!
Old Oct 4, 2012 | 03:30 PM
Biggie G's Avatar
Biggie G
haha
good stuff.
yeah that almost happened to me too
Old Oct 4, 2012 | 06:29 PM
VET4LES's Avatar
VET4LES
I've been working on cars over 50 years and never made a mistake.
If this is your first mistake don't let it get to you. That's how we all learn.
Old Oct 5, 2012 | 09:29 AM
robertaj's Avatar
robertaj
How could you install it upsidedown ? the screws are offset....
Old Oct 6, 2012 | 09:56 AM
Allen_B's Avatar
Allen_B
^^ I have proven that with enough determination (and beer) the impossibly simple can be unachievable! Square peg in a round hole is nothing!
Never underestimate the power of determination and in the OP's case, lack of sleep!
/r
Allen
To Ruined my MAF!
