Transmission Interchangeability
Old Oct 3, 2012 | 10:57 PM
bullitt4110's Avatar
bullitt4110
Default Transmission Interchangeability
My 2006 Z51 M6 car needs a trans and I may have found one from a 2005 Z51, my question is are they interchangeable? I only ask because I know the diff was changed in 2006 and I wasn't sure if the shaft going into the diff is the same splines or not? Thanks.
Old Oct 4, 2012 | 09:53 AM
Schoolteacher's Avatar
Schoolteacher
The splines are the same, but you till have to change the tail housing to make it bolt up.
Old Oct 4, 2012 | 10:53 AM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Correct!
Also, make sure to change over the shims under the extension shaft end bearing race to the new tailshaft housing. If the clearance isn't right, you can have premature bearing failure.
__________________
Old Oct 4, 2012 | 12:50 PM
bullitt4110
So not really a direct bolt in? Thanks for the info.
Old Oct 5, 2012 | 08:50 AM
CMY SIX's Avatar
CMY SIX
go up not back.
To Transmission Interchangeability
