2005 HUD won't work
Old Oct 16, 2012 | 10:58 PM
MaggieH's Avatar
MaggieH
8th Gear
Default 2005 HUD won't work
Ok, I have a 2005 and the HUD won't work, I can see a green light when I look down at it, but no display on the windshield... Any suggestions would be great!!!
Old Oct 16, 2012 | 11:03 PM
EVRose's Avatar
EVRose
The up/down arrow buttons wont move it? Can you hear anything when you push the buttons? If so its probably broken inside or came apart which has happened alot. Do a search here for hud not working for fix options.
Old Oct 17, 2012 | 10:11 AM
EyeMaster's Avatar
EyeMaster
Could it be the wrong windshield?
Old Oct 17, 2012 | 10:49 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Even the standard windshield should show a fairly good image. If the up/down adjustment isn't the problem, and you don't want to have it replaced by a dealer, contact Andrew6 and see what he can do for you.
Old Oct 17, 2012 | 03:31 PM
Legal Alien's Avatar
Legal Alien
If you're handy with a tool kit it is very simple to get the HUD out. The process is documented at length here on the forum.
If you're not confident removing the steering wheel and dash cluster etc then you need to be paying one of the excellent vendors on here to replace your HUD. Another vote for andrew6, top bloke.
What has happened is your mirror has fallen off the brackets very likely because the bracket has snapped/perished. It is very common and exactly what happened with mine. They are made of cheap crappy plastic.
I'm from the school of "anything can be repaired" but many are not so you may want to purchase a reconditioned/new HUD. They are iro 350 bucks I believe.
Good luck with it all!
Old Oct 17, 2012 | 09:27 PM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
Great time to replace with a Color Heads Up Display.
Where are you located at?
Note: These are on non HUD windshields; If you have a HUD windshield the clarity will be slightly better.
Old Oct 17, 2012 | 10:04 PM
BEZ06's Avatar
BEZ06
with Legal Alien!!
Here's a post I made in another thread about this problem. I was up in NJ and my b-in-law's HUD wasn't working, so I hunted around and found the video I link in the post, and I fixed his HUD exactly like in that video:
http://forums.corvetteforum.com/1581526306-post10.html
Bob
Old Oct 19, 2012 | 05:12 PM
MaggieH's Avatar
MaggieH
8th Gear
I am located in northwest Arkansas
Old Oct 19, 2012 | 08:30 PM
Former Vendor
I'm in Houston, don't know if that helps you
To 2005 HUD won't work
