Hearing Brake Light Relay?
Thanks!! for any info.
If it bothers you, you can get a new relay and hope that it will be quieter. Or, a member here went to the effort of adapting a solid state relay (silent). If you want to read about it here's the thread:
http://forums.corvetteforum.com/c6-c...-solution.html
And just FYI so you know you aren't alone in not liking that noise, here's a TSB from 2011 where GM came out with a new part number relay, which "should be" on your 2013 already.
http://forums.corvetteforum.com/1581463666-post5.html
My car is a 2012 GS, so it supposedly has the new relay too. Can't imagine a noisier one
. Oh, and how about the reverse relay? It's just as noisy as the brake one
. Saw that SSR fix, but the noise doesn't annoy me that much to make such a wiring mess. What I plan to do is look for a piece of rubberized insulation foam like the one under valve covers (it's heavy), and make 2 'caps' for both the brake and reverse relays. With that, it should be almost silent IMO. MUCH easier solution for me. Maybe in a junk yard. It has to be that heavy stuff, or it wouldn't work.
If the sound was intermittent or grating or evidence of some malfunction, it would be annoying to me. But it's none of those things. It's just another sound that the car makes when I operate a control.
The door window motor whirrs when I open the door, the windshield wipers swish when I turn them on, the parking brake ratchet clicks when I pull up the lever... and the brake light relay clicks when I press the brake pedal. I have no problem with any of those things, whether the car cost $70K or $7K.
