C6 Vert Rollbar options
Tamer
Thanks for playing 20 questions...
Tamer
there are a few organizations that allow convertible without rollbars, your best bet is to run with those groups
Thanks again.
Actually, some racing groups say two inches, OR, as high as it will go inside the top. The BPP certainly has less than an inch clearance.
MAYBE its stiffer, if it was, it wasn't especially noticeable.
And yes, the seats can no longer go all the way back. No problem for me at 5'10", but that is with the drivers seat as far back as it will go. Taller passengers can look uncomfortable.
I added some BCSI roll pad to the bar, maybe only half an inch thick on top, and the top still went up and down, though now it is CLOSE.
I also found I needed to cut off the extra length of bolt hanging down below, as I managed to whack one of them once. Like a large hammer stroke on the end of a hollow pipe. Wow that was loud
I am concerned if I could fit, I don't sit with the seat all the way back but close, but when you road race you tend to move the seat up further and more upright. I appreciate your thoughts.
The NHRA rule is very explicit.
"All vehicles with OEM frame must have rollbar welded or bolted to frame"
It's pretty clear that C6's have a frame, therefore if any part of the rollbar is not directly attached by welding or bolting to the frame, it can't be NHRA legal.
There are those who claim their rollbar is NHRA legal, whose rollbars bolt through the floor or attach to the sheetmetal ridge at the front of the cargo floor. It's obvious in the photos of the Corvette rollbar on the rpmrollbar site that it does not attach to the frame.
It'd be interesting to see the wording in their guarantee they boldly proclaim on the rollbar page. It sounds like they know it's not legal, but count on tech guys not investigating, not caring, or not aware of the rules. Some tech guys would pass PVC pipe with just a quick glance, but that doesn't make it NHRA legal.
The extension kit to be legal to 8.50 ET would also require NHRA certification, which is a whole different level of inspection beyond the 10.00 rollbar requirement.
