Catch Can install question
Old Oct 24, 2012 | 03:10 PM
RainMan12's Avatar
RainMan12
Default Catch Can install question
Most catch cans have a small filter screen on one of the ports, to try to make the oil mist condense on them and filter the liquid spray from the air, and the other port goes directly into the can.
So which port should go where in relation to the crankcase and throttle body ports? Should the side of the catch can with the screen on it go to the throttle body port or the side the goes to the crankcase breather?
Old Oct 25, 2012 | 09:51 AM
RainMan12's Avatar
RainMan12
Anybody?
Which port on the Elite Engineering can goes to the throttle body, and which to the crankcase vent?
Old Oct 25, 2012 | 10:20 AM
mikeCsix's Avatar
mikeCsix
These catch cans seem to work pretty well. I have one installed on mine too.
The way I think of the catch can is an inlet and outlet, since you want to filter the air of oil contaminant, the top of the can is the inlet, the side is the outlet.
The goal is to filter the air before it hits the throttle body, so you want to insert the catch can in the line between the crankcase and throttle body - so the crankcase feeds into the top of the catch can and the throttle body connects to the side. By doing so, the oil condenses in the mesh and falls to the bottom of the catch can and air for the throttle body is drawn off the side.
Old Oct 25, 2012 | 11:12 AM
Mike's LS3's Avatar
Mike's LS3
MikeCsix is correct - top of can goes to the manifold, side of can goes to throttle body. Elite has instructions on their website. I installed one recently, very good quality, easy install and it works.
Old Oct 25, 2012 | 01:27 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Had one on mine for several years, works great.
Old Oct 26, 2012 | 11:03 AM
Rev Xtreme's Avatar
Rev Xtreme
St. Jude Donor '13
Which catch can do you have? You have to watch out what brands that you purchase because most catch cans are just empty shells with maybe some material in there to catch some oil mist. A lot of the cans are too shallow and therefore will leave some oil vapors in the can, but pick back up most of the harmful byproducts and bring them back into the motor. Our particular catch can has a perforated tube down the middle to separate the harmful byproducts & additional oil blow-by. The deposits are made into the bottom of the can, where they cannot be picked back up from normal airflow as a lot of other cans have. We have about 20 brands of different cans here all cut open.
The Elite Engineering Catch Can is actually one of the best cans on the market just so everyone knows. You cannot go wrong with Elite or RX !
Here is a cutaway of our can.
Old Oct 26, 2012 | 06:28 PM
victorf's Avatar
victorf
In basic form, Elite is very high quality. With a few additional mod, Elite gets better plus can take apart for 100% cleanup + visual verification.
Here is the unscrew, separated view with a couple of mods:
http://i896.photobucket.com/albums/a...6/P1010334.jpg
Old Oct 26, 2012 | 06:42 PM
JCtx's Avatar
JCtx
To me the best can itself is AMW. Have you open one? It's very similar to EE, but it has grooves inside the can, to prevent oil from creeping up the can walls with high vacuum. I bought EE for my previous Vette and GTO. To me, it boils down to their brackets. EE has a better engine bracket. But with the Helmholtz chamber on the GS, AMW has a better bracket where I installed mine (looks OEM). Those 2 are the best cans IMO. The most expensive too, but as you said, you get what you pay for. By the way, EE is too wide for my application.
Old Oct 27, 2012 | 01:46 PM
victorf's Avatar
victorf
The supplied mounting bracket from Elite gave me 1/8" clearance from the heater hoses and at a slight tilt once mounted, just too close for comfort. Additionally, to unscrew bottom reservoir, catch can need to be removed from arm due to lack of bottom clearance. Total inconvenience for me!
Consequently, made my own, based on the two intersecting angle on the head and milled cavity on lighten T6 bracket to precisely fit the head corner, milled cavity also assure mounted catch can perpendicularity. Once mounted, I have an inch of clearance from the surrounding heater hoses, inlet/outlet hoses to the catch can elevated/away from direct engine heat contact, elevated catch can is insulated from engine heat/exposed to 360* ambient air and ample clearance at the bottom to unscrew reservoir for cleaning convenience.
http://i896.photobucket.com/albums/a...6/P1010351.jpg
Updated view:
http://i896.photobucket.com/albums/a...6/P1010352.jpg
Old Oct 28, 2012 | 03:11 PM
victorf's Avatar
victorf
"Have you open one?"
I have seen the inside! One thing I have noticed is the outlet location is fairly close to the inlet tube (end contained the mesh) and with no physical baffle to slow down the blow-by other than the anti creep grooves. Inlet end with the mesh is relatively high off the bottom of the reservoir, for a good reason, given the mesh housing/inlet has no bypass, if it is long enough and close to the bottom (which is a good thing in terms of further distance from the outlet) but existing design, mesh might get submerged in captured blow-by, if timely draining is neglected.
On the other hand, Elite mesh housing (way off the bottom) has flange at end (acts as physical baffle barrier) and raising blow-by has to squeeze around the flange into and through the cavity in top housing to escape. That is simple and ingenious. Although the distance between inlet/outlet is short, but a person can simply address that with an extension.
All in all, no one brand is perfect!
Someone else can find flaws with my alterations to the Elite, I am sure.
But that is the fun part, not accepting what is out there and the constant pursuit of making things better.
To Catch Can install question
