Brake pads replacement
True?
I do HPDEs so I'm not going to cheap out on brakes but if it isn't necessary,,,,,,,
If you're getting a new set of OE pads, they come with new pad pin bolts - in which case I'll take your old ones!!
However, if you're going with some aftermarket pads you definitely do not need to replace the bolts at every pad swap.
My 2006 Z06 has 45,000 miles on it, and about 4,500 are track miles. I recently put on a new set of calipers off a GS, but until then my old calipers were running the original bolts.
Here are my old calipers that I just recently sold. You can see that the pad pin bolts in the first couple years of Z06 calipers required an Allen wrench, whereas yours require a T-45 Torx bit.
My old calipers had many, many pad swaps. They went through a lot of track pads, and then back to street pads between track events.
I removed the pad pin bolts a couple time to replace pads while the calipers remained on the car, but it's much easier to just remove the calipers to replace pads.
If you're going with one-piece pads instead of padlets, then you'll definitely need to remove the calipers!! Here's a one-piece in one of my new calipers:
Good luck with the pad swap, but it's a very easy job!!
Bob
Here are some on the inside of the caliper where they where they hold the padlets in place and allow them to slide in and out with piston activation:
Your avatar shows a base C6, and the caliper "pins" on them are entirely different from the pad pin bolts on the PBR Z06/GS calipers.
GM charges something like $10 per bolt!!! And there are a 8 pad pin bolts in each front caliper, and 6 in each rear - total of 28 bolts.
There are some good aftermarket ones available with 10mm hex heads for about $230 for a set of 28.
Bob
Bob
Thanks,
Thanks,
I'd recommend you run something like Hawk HPS or Carbotech 1521 Bobcats for the street, and swap to Hawk DTC70 or 60, or Carbotech XP12 or 10 for the track.
The aggressiveness of your track pads has to match the stickiness of your tires, so what tires are you running on the track?
There's no such thing as a pad that will work properly for both situations.
The more important thing is to make sure you flush in a good high boiling point DOT 4 fluid into your brake system.
If you need a set of HPS pads, I have some ill sell:
They look brand new (you can see they look to be "new" thickness), but there are round piston marks on the backing plates like somebody mounted them up for a very short time.
The fronts are one-piece, and the rears are padlets.
$240 shipped to your door.
Actually, you should drive over to my house in Daytona and we'll put those bad boys on your car and flush in some DOT 4 fluid. The pads will go for $220 if I don't have to ship them, and we can get some good Motul RBF 600 from the motorcycle shop I get it at over here for about $18 per 500ml bottle, and well need 2 bottles.
So drive on over and well get you new pads and fluid for around $250.
I hope whoever you're working with in Tampa isn't too much more than that!!
Bob
I'm signed up for Sebring on the 3rd and must work hard this week to pay for it.
I understand I'm giving up some with HPS instead of HP+ or DTC but the car spends much more time on the street than track and I'm not fast enough to out drive the pads or tires (stock GY Supercars) at the moment. Perhaps by the time I wear these out ill be ready to make tire/brake swaps for my track weekends.That's a real good price on those pads, even lightly used. I'll keep them in mind for my next set if you still have them ( and if I like the ones I'm getting installed).
BTW. The first thing I did with the GS was SS lines and Motul600.
