Dyno pulls w/A6
Old Nov 7, 2012 | 10:57 PM
Redrocket1045's Avatar
Redrocket1045
Default Dyno pulls w/A6
I know that when you have an A6 on a dyno - you should have it in 4th gear.
Question is: will your car show a higher hp and torque numbers if you lock up the converter using HP Tuners or just running it as is? I have an educated hunch but what does the majority say?
Old Nov 8, 2012 | 12:09 AM
madmax4499's Avatar
madmax4499
I use the paddle to select 3rd. I dont think the dyno cares if it is 3rd or 4th. next time i will try third and fourth to see what is up. Yes i know 4th is closest to 1-1, mine is tuned to lock at WOT depending on gear and speed
