The instructions that came with the Vararam wedge state that for custom tuned vehicles that (quote: this product offers substantial gains; these gains will result in more airflow which means more MAF scaling. Some vehicles that have been custom tuned may need to be re-tuned so the MAF does not over scale. Using the LS3 wedge spacer MAF scaling will rise substantially at lower/mid range RPM levels, + 175-250HZ, peak HZ is usually +90-120HZ) My 08 LS3 falls in this category and after installing a power wedge to my Vararam CAI the car is now throwing a MAF code. the car was not re-tuned after instillation on the advice of the dyno shop that had previously tuned the car. Frankly after questioning them about re scaling the MAF I am not convinced they understand how to do this. If anyone here is familiar with what is required to re scale the MAF and under what conditions a dyno tuner would re scale the MAF I would appreciate an explanation.
I really don't put much stock in dyno tests, so I'd like to see some timeslips. Since it's a simple 10 minute install, a test at the track would tell the real world difference.
3 passes to establish consistancy, then 2 passes with the wedge to show the difference, and 1 more pass without the wedge to verify a return to the previous numbers and eliminate DA and track condition variables.
I'd gladly pay $100 to cut as little as a verified .05 off my ET.
I have one on order and was planning to do just that.
Thanks for being the guinea pig and test platform.
If you do this, please mark the time of day on the slips, because you only get half slips.
You had a strong run for a 3200 stall. Did you get consistant 60' times?
You pull some good mph and ET! Care to divulge any tips or info?
Differences?
3600 Yank - to get 1.5x 60' times
cat-less - w/Z06 mufflers
probably weight - I get **** when trying for a PB - under 3000#
seat time - over 300 passes with this car
The little details add up, so keep track of each pass and the DA at that time. Then you can make adjustments, corrections, or mods and be able to determine if they were good or bad.
That was with no tuning. The Power Wedge was really easy to install and uses the stock bolts.
Did you keep it untuned or did you tweak it after getting the dyno numbers? If you left it untuned, do you know how long and how many miles since the install? Have they/you experienced any issues?
Sorry for all the questions but there doesn't seem to be many people with this mod.
so a stock tuned car or a tuned car before the wedge? It looks like the orignal test was done on a tuned car then you added the wedge and did not retune?
Also a question I have, in a stock tune the MAF can adjust for air differences to a degree. When you get a custom tune do they take away the ability for adjustment for air changes? Im assuming thats why a tuned car needs to be retuned?
I have the same question. It's the only thing holding me back from purchasing.
I think I found the source of the engine code (PO71) after the Vararam CAI & wedge was installed. The code was caused by an intake air leak. The PCV fitting was hanging loose (not installed in the intake).
I got and installed power wedge on my 2012 GS. I didnt notice any diference, actually i feel like i lost acceleration speed with it. feels like throttle is lazy and slow after install.
Im getting headers put on in 2 days, maybe it will work better with it.
Honestly, I doubt many would be able to feel 6rwhp/5rwtq as witnessed in the posted dyno sheet. Or even the claimed 8-10rwhp from VaraRam. But, I'd be willing to accept a confirmed 6+rwhp for $100. Still researching.
PS: Take the wedge off at first with the new headers, than after a few track runs, etc. add the wedge "OR" do it the other way around.
throttle response is what bothers me. It should have improved it not made it worse. Glad I got the cow booster to solve that. Sounds like a 100 I wont be spending now and will probably just do a water/meth kit which usually results in about 20 to the wheels and keeps the engine clean.
I looked at the wedge, it redirects the incoming air upward into the intake manifold which may or may not improve torque, etc. However adding length after the throttle body may also cause what "Dado5" felt IMHO.
I thought adding length to the plenum (if thats what its doing too?) helps keep more air in it to help with throttle response as the air is already there and doesnt have to wait for blade to open up?
Plus they say a stock car doesnt need to be tuned. So some more field work is needed by members I guess.
