swapping ls2 for a ls3 question......
Old Nov 21, 2012 | 11:15 AM
staki's Avatar
staki
Default swapping ls2 for a ls3 question......
ive got a 2007 ls2 with auto trans, and im installing a ls3 also out of a 2007 complete with manual trans.
will everything just plug in and start up? or does anything ave to be modded? the stock ls3 has everything on it, simply taking it out and replacing the ls2, ls2 is blown.
id appreciate any input to make this as easy as possible without finding out the hard way.
thanks
Old Nov 21, 2012 | 11:16 AM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
LS3 didn't come in a 2007. They started in MY 2008+.
Look up a thread by taken19. He did something very similar to this and posted a lot of the info.
Old Nov 21, 2012 | 11:25 AM
staki's Avatar
staki
hmmmmm, ok, that could be really easy then. i guess maybe the plastic covers where just changed, ill look in to it. check the vin
thanks
Old Nov 21, 2012 | 11:32 AM
JUIC3D's Avatar
JUIC3D
You'll definitely want to be sure you're getting what you paid for. There is a substantial difference in the LS3/TR6060 combo vs. the LS2/T56.
Old Nov 21, 2012 | 12:13 PM
staki's Avatar
staki
yup engine codes are both "u" , i guess the person before me just changed the covers to feel better about themselves. i guess the 2007 ls2 to 2007 ls2 swap shouldn't be to complicated
Old Nov 21, 2012 | 06:58 PM
jonathontodd's Avatar
jonathontodd
Sucker born every minute
Old Nov 22, 2012 | 08:33 AM
JUIC3D's Avatar
JUIC3D
Hopefully you didn't pay the premium price for the "LS3" when you got a LS2..
Old Nov 22, 2012 | 10:23 AM
taken19's Avatar
taken19
Track Junky
LS2 to LS2 swap should be able to be done in a weekend.
2006+ LS2 to wet sump LS3 should yield the same results.
2006+ LS2 to dry sump LS3 tougher due to battery relocation, oil tank mounting and all MAP/MAF pigtails and tuning needed.
2005 LS2 to dry sump LS3 pain in the a$$. Same as above plus conversion box to engine harness to convert 58 tooth reluctor signal to 24 tooth ECU requirements. See below.
http://forums.corvetteforum.com/c6-t...-sump-diy.html
To swapping ls2 for a ls3 question......
